V8 twin turbo m278 in Mercedes w204 c300 AWD, A/T.
Old Aug 27, 2022 | 04:23 PM
pyatka's Avatar
s500
Hello, I want to do a project to put m278 engine in c300, AWD, A/T. What do you think about?
Old Aug 27, 2022 | 08:52 PM
chassis's Avatar
2017 GLE350 4MATIC
The M278 TT was never installed in W204, you realize this, correct? What is your plan for exhaust including turbos and exhaust manifolds? There will probably be a challenge getting the front axle centerline where it needs to be for the front knuckles/uprights. You will need to use a transmission/transfer case assembly that works with M278, which then establishes the front axle centerline relative to the engine block/oil pan. What about engine height? Will it fit between the front suspension crossmember and steering rack, and the hood?
So many questions.
Old Aug 27, 2022 | 09:28 PM
pyatka's Avatar
s500
M273 fits perfect in 2010 c300 with m272 , why m278 not fit in 2013 c300 with m276?
Old Aug 27, 2022 | 10:51 PM
joeshannon095's Avatar
2018 S560, 2004 SL500, 2014 S550 (SOLD), 2012 S550 x2(SOLD), 2007 CL600 (SOLD), 2007 S600(SOLD)
Can you get a rear drive model? That might open things up for you a bit
Old Aug 27, 2022 | 11:04 PM
pyatka's Avatar
s500
No, I want AWD!
Old Aug 27, 2022 | 11:48 PM
chassis's Avatar
2017 GLE350 4MATIC
What do you know about the M278 vs M276?
What do you know about the M273 vs M278?
What has your due diligence revealed?
Old Aug 28, 2022 | 12:13 AM
pyatka's Avatar
s500
I know nothing about the M278 vs M276?
but we just finish a project m273 in 2010 c300 rwd 6 speed.
That's why I want to start a new project
Old Aug 28, 2022 | 07:47 AM
chassis's Avatar
2017 GLE350 4MATIC
Looks great. The M273 is a shorter stroke and smaller displacement engine than the M156 which was fitted in the W204 from MB.
Not surprising the smaller M273 fits in the large hole created for the M156.
Do more homework on the M278/M157 and tell us what you find.
Old Aug 28, 2022 | 01:45 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Somewhat. You know the 63 model has a slightly extended front end. This is a 300 body.
Old Aug 29, 2022 | 01:48 PM
TheWeirdJon's Avatar
2008 C350 with S550 5.5L V8
I have a M273 motor that I plan on swapping into my c class, did you have issues with the ME97 ECU? I have the harness from the m273 and I bought the motor for $2000 from an S550 RWD with 71K miles. I’m planning on swapping it, but I don’t think that the the old ECU will work. Are you located near Dallas, Texas by any chance?
Old Aug 29, 2022 | 09:46 PM
pyatka's Avatar
s500
I'm in Brooklyn NY. Use ecu from 11-12 s550,e550.
Old Sep 7, 2022 | 03:43 PM
Adi-Benz's Avatar
Alright Jon this is the work we like to see...have an instagram or plan on showing updates here?
Old Nov 20, 2022 | 05:11 PM
readegodbody's Avatar
w204 c300
Yes it’s possible mbhousetoronto on instagram did it
Old Dec 27, 2022 | 08:41 PM
IG is JonTheTeaMan
Motor has been out for 3 days. Doing test fitment and transferring accessories to the v8 motor. I’ll make a new thread when I make real progress. All I need is my ECU to come in. I also have the other set of wheels for the rear when I finish (gold all around for a uniform look).
Old Dec 28, 2022 | 08:45 PM
Adi-Benz's Avatar
Looking good!
