A/C works sometimes
Do you have access to a high end scanner to see if any A/C codes show up?
A long shot would be a very worn blower motor with bad brushes or an intermittent internal fault.
The control voltage to the blower shows 5 to 6 volts and the refrigerant pressure between 10 and 14 bars
what is the normal?
i could get codes on Icarsoft
Now the next thing I want to ask your opinion is that when the temperature is hot outside, the A/C blows straight hot air for a while and may be 2 miles before I guess the compressor kicks in and starts blowing cold air.
The other cause would be gas on both sides of the system which would be a refrigerant charge issue. But your pressures are right so your charge should be okay.
If you are sure it’s not very high temp in the passenger cabin, e.g. the car is parked in a garage, then the car will need to be started then the hood opened to see if the compressor clutch is engaged. I think your iCarSoft can be used to see where the bad component is.
