Cluster display is dead
Old Oct 8, 2022 | 11:34 AM
toffee21's Avatar
C220 CDi
2010 C220 CDi
Out of the blue my dash cluster is dead, no lights, no gauges working, no idea of fuel level or speed, engine starts ok and drives, indicator work but there is no clicking sound, they cancel ok
other stuff works ok, radio, air con etc
Could this just be a fuse?
Old Oct 8, 2022 | 11:45 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Fuses usually don't blow for no reason...Fuse 28 in the front driver's side engine fuse box (7.5 amp) is for the instrument cluster on your year C class. If you still have your fuse location sheet you can double check. Past posts suggest the instrument cluster has failed ..loose connector unlikely since it has an active lock. Used clusters are online but don't know if they have to be sync'd with the car. ECU. Maybe someone else can comment on that.
Old Oct 8, 2022 | 12:15 PM
toffee21's Avatar
C220 CDi
Just checked the fuse and seems intact, I briefly disconnected the battery to see if that would reset it, but no joy
Old Oct 17, 2022 | 06:54 AM
toffee21's Avatar
C220 CDi
Took it to a mechanic, he checked all fuses and all ok, I did notice that my battery is losing charge, I wonder if I have a failing battery and would this cause it
it was 12.6v yesterday, sat overnight and I checked it this morning and reads 12.3v
Is my battery faulty?
Old Oct 17, 2022 | 01:15 PM
Russell Ormerod's Avatar
not a merc
If you have a spare key try using it
Old Oct 21, 2022 | 10:27 AM
toffee21's Avatar
C220 CDi
I have the other fob somewhere, just need to find it!
Old Oct 22, 2022 | 02:23 PM
toffee21's Avatar
C220 CDi
I have found the other fob but still no good
Old Aug 8, 2024 | 10:24 PM
ap10046's Avatar
CLS500 M113
Resurrecting an older post.
Same issue. 2013 w204.
Everything works normally but the instrument cluster. Did anyone find a workaround?
