2nd gear problem 6 speed manual
Old Oct 8, 2022 | 04:19 PM
cossiejay's Avatar
220 cdi se
can not get 2nd unless i really force it in every other gear is fine changed the oil and gearbox mounting are the selectors adjustable
Old Oct 8, 2022 | 04:23 PM
chassis's Avatar
2017 GLE350 4MATIC
Generally not adjustable. If you can eventually select second gear, and there are no noises or vibrations, the synchronizer could be worn out.
Second gear is down (toward the driver), and so is fourth gear, correct? Can you select fourth gear with no problem? What about sixth gear?
Old Oct 9, 2022 | 06:18 AM
cossiejay's Avatar
220 cdi se
yes thats correct and as i stated i can select every other gear with no problems at all
Old Oct 9, 2022 | 10:40 AM
chassis's Avatar
2017 GLE350 4MATIC
Then it sounds like the selector lever (gear shift lever and linkage) is not the problem.
Sounds like the synchronizer is worn. Can you double clutch or rpm match to smoothly select second gear?
Old Oct 9, 2022 | 12:40 PM
cossiejay's Avatar
220 cdi se
no it will not slip in at all also 6th works but does not seem like its fully engaged but still goes in without a problem
Old Oct 9, 2022 | 01:37 PM
chassis's Avatar
2017 GLE350 4MATIC
Sounds like the second gear synchro is knackered. Either replace with a new (rebuilt) box or send it to a rebuild shop, if such a shop exists.
Old Oct 11, 2022 | 12:44 PM
cossiejay's Avatar
220 cdi se
i would like to add it will not go in 2nd gear even with the engine off it really seems like it is not being pushed all the way in
Old Oct 11, 2022 | 09:57 PM
chassis's Avatar
2017 GLE350 4MATIC
Have a read through these. Seems a known problem and the only solution is synchro replacement/box rebuild or new replacement box.
https://mbworld.org/forums/c-class-w...t-6-speed.html
https://forums.mercedesclub.org.uk/i...l.97120/page-2
