Part identification help
Old Nov 9, 2022 | 06:35 AM
Ronald12's Avatar
2007 E320 Bluetec and 2008 C350
What is this part called?
2008 C350. I would like to replace the damaged part shown here. Does anyone know what this is called and I if it can be replaced? Thanks so much.
Old Nov 9, 2022 | 08:47 PM
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
See this link: https://www.mbonlineparts.com/v-2008...rior-trim-roof
The part would be #2 which that website does not sell anymore but you will get the part numbers which you can google after.
It does come off as its held on by clips, start from the roof back and then work your way to the windshield.
Old Nov 10, 2022 | 07:21 AM
Ronald12's Avatar
Thank you Mikey! Exactly what I was looking for sir!
Old Nov 15, 2022 | 11:52 PM
Russell Ormerod's Avatar
not a merc
It can also be cleaned. Sanded and polished back to original shine. Takes time but can be done
Old Nov 17, 2022 | 12:21 PM
Ronald12's Avatar
Hello Russell,
it is the black rubber piece that’s goes along the side of the windshield. That can be sanded and polished? If so, how or what would I use? Thanks!
Old Nov 18, 2022 | 03:40 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Originally Posted by Ronald12
Hello Russell,
On my car (2013) it’s actually plastic and not rubber. Remove it carefully from the back. It can be sanded down to the bare material with 600 grit wet sand paper. Then it can be restored to the original finish with solvent based clear acrylic spray. Reinstall after it has dried hard.
