New Member - Tyler
#101
"Proprietary rivets"? What BS that is! How is a rivet proprietary? And even if it is, use a nut and bolt and Loctite (red) the nut in place.
By the way, every window regulator I have ever worked on has been riveted in place. You drill out the original and replace it with another rivet or a small bolt and nut.
@FIREfreezerC250 Sorry to hear you’re getting hosed on costs. To keep an older Benz without a warranty, you’re really gonna have to tackle stuff like that yourself.
#102
Received 1,530 Likes
First, there is no excuse for returning a customer's car dirtier than when they brought it in. That kind of sloppiness makes me question the quality and thoroughness of the other work done. Second, avoid automatic car washes! The ones that use high pressure water will certainly get water somewhere inside the car. The ones with spinning brushes or heavy cloth strips that undulate back and forth are likely to scratch the surface of the car. I understand if you can't wash a car where you live, but there is likely one of those wash-it-yourself places where you feed a bucket of quarters to wash the car for five minutes.
#103
Yes, I am realizing that I will never use one of those automatic car washes again.
@Odd Piggy I agree, I need to start doing stuff like this myself. I just didn't want to mess the door up and not be able to put the panel back on correctly. But what should I do about my speakers? Do you think it was a fuse that has blown? And if so, where is that fuse located? I know there's a fusebox in the engine bay, another under the steering wheel, and another right next to the right brake light.
I just don't understand how MB makes their cars so that they can't even get wet without shorting the speakers....
#104
How old is your car?
#106
I kinda meant that you have an 11 or 12 year old car. Not knowing its life history, it may not be fair to judge good or bad.
#108
C250 W204 Chassis, M271 evo engine
P0068 and P0106 in my C250 2012 W204 M271
I have two different Code P0068 and P0106,
Car run perfect with no issue, I replaced Map sensor locate at Intake Manifold and Booster sensor locate before throttle Body and Barometric sensor on top Intake Pipe, after like 30 miles both codes back again especially no vacuum leak at all,
any suggestions to fix this issue
