E Class to C Class
Old Jan 17, 2023 | 12:24 PM
cc1canada's Avatar
2011 C250
E Class to C Class
I have a 2011 C250. Have opportunity to buy some winter tires and rims. They are off a E350
Tire size is good at 225 45 17
However I am not sure about offset and lug bolt shape.
Can anyone advise if they will work?
Thank you
Chris
Old Jan 17, 2023 | 06:32 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W204 forum...
offsets are different...
Old Jan 18, 2023 | 08:56 PM
AAIIIC's Avatar
2014 C250 Luxury
Without knowing which specific E-class they came off, no, nobody can answer the question. You can easily search for the wheel specs for either model - look them up and compare.
Old Jan 19, 2023 | 05:09 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
The Mod says offsets are different from C to E. The offset of the E wheels is cast into the inside one of the spokes. It’s identified by the letters ET.
The number is millimeters (mm) so small differences can often be tolerated. Any tire store should be able to tell you if it’s safe with the tire size, rim width, and wheel offset.
