Will taller tires affect 4matic?
I've spent the last few hours reading through archives on here and not found a clear concise answer to this question: Can I go up 5% in aspect ratio (sidewall height) on the front and rear tires of this car without causing problems in the 4matic system?
The guys at the Nat Tire and Batt I used to go to said no. Dealership just passed me back and forth between parts and service like they did when I asked about differential capacities(won't ever call them again period....not even if they were giving away cars (longer story)).
The fronts would go from 25.1" > 26", rears from 25" > 26". Revs per mile will go down 804 > 776 front, 804 > 777 rear which will cause speedo to read slightly lower than actual. It's basically a 15/32" top and bottom front and a 1/2" top/bottom rear height increase which comes out to 3.6% increase front and a 4% increase rear. And possibly a 100% increase in my sanity!
Fender and suspension parts clearance is another matter that I can’t comment on.
I got it, was on way out door when read your answer and sent that reply. Figured out what you meant by bottom of driveway
4matic system prefers that all four tires be the same diameter whether 25", 26", or 40" Thank you.
A set of Interco Super Swampers will solve this problem once and for all!
Our 4matic came staggered w/ 225/40 front 255/35 rear and 18" AMG Sport package wheels. Going down to 17's would def help, but is a last resort.
My wife has what may be the world record of 17 road hazard claims with this car lol. In fairness 6 weren't her fault, 4 reverse rotation at NTB and 2 from an accident in front of her where she ran over the scattering debris. All but one happened while under the wheel/tire warranty. That one resulted in a cracked front wheel which I TIG welded about 2yrs ago. The weld finally gave out last week so I sanded, cross hatched and repaired with 3 thin layers of JB Weld; and started looking for a new wheel. The 18" AMG 7 spoke 8" 50 offset front wheels are 4x the cost of a rear and as much as 4 low end aftermarket wheels! So I started entertaining an aftermarket set or possibly buying two more 8.5" rears and running them on the front?
She drove about 4400mi after NTB rotated the 255's to the front and put the 225's in rear. During that stretch the 255's rubbed the paint off the front struts. So I know the 8.5" 54mm rear wheel with 255/35R18 is just a little too big for the front end...
Granted she's a much better driver now but I still want to give her some taller sidewalls to work with...
Best case scenario would be to get away from the staggered setup so tires can be rotated to all 4 corners, increase sidewall height to mitigate potential future issues, and do both W/O sacrificing ANY lateral grip!?!?
Just put car up to replace front and rear diff oils, trans oil, and rebuild sticking pass rear caliper. When done with those I'm going to pull all 4 wheels and measure meticulously to see what I can get away with on tire size. I'll let you know how it goes lol
17's will be last resort honestly. I realize that would make this puzzle a lot less difficult to put together, but aesthetically Im afraid 17's might rekindle her fire for an S5 lol. I just talked her into keeping this by giving her interior a reverse colors makeover, changed all black buttons to satin silver and changed steering wheel trim piece and emblem from silver to gloss black. Wrapped all burgundy wood in textured black Ash vinyl and clear coated. Turned out gorgeous but I love no payments and having a vehicle that I know the history of
In the week of expanding my offset knowledge, available space measurement skills and trying to decide on new wheel/tire size; I kept checking my local market for a set of usable 5x112 wheels.....and kept seeing these 3 sets of 19" Audi factory wheels. Two had decent list price and no tires. One set had some very meaty Michelin Pilot Sport AS4's and low list price $700. So after some research into reaming out the center bore from Audi's 57.1mm to our 66.56mm, I made an offer of $125 a piece on a set of 19" wheels off of a 2019 Audi RS3, and he accepted. I went picked them up, spent about 2min per wheel using a router w/carbide bit removing less material than half my wife's bracelets, along with about an hour turning the center caps from black w/four rings to something that looks like it could've been there all along(?)
And the result: Def not a purist route, but I've seen much worse.
For $500 bones I got: RS3 Fronts 19x8 42mm offset and 235/35ZR19 Mich Pilot Sp AS4 & RS3 Rears 19x8.5 46mm and 255/30ZR19 Mich Pilot Sp AS4. New the wheels are $3300 + install. Ebay used wheels $1449. Tires new $278 front, $320 rears; came with 10/32nd new and I gauged at 9/32 11 of 12 places, 8/32nd in the 12th.
No rub at all and the extra 8mm in poke fills out the space nicely. The over/under on her destroying one or more was set at 55 days. I took the over out of a show of support for my wife's promise to be more attentive DOWN the road! I got about even money from my boys, 42 days to go lol
B4 center caps
w/remodeled center caps
front stance
rear stance
They currently sit in the front of our garage whilst the car rolls on 235/45R17s. I'd go smaller diameter wheels (and higher profile tyres) but the brakes don't fit under 16" wheels.
Same reasoning as yours.
Yes its an Audi Quattro and not an MB with 4Matic or 4Matic+, but the same basic principle apply. The issues start when you have a substantial rolling diameter difference between front and rear axles (or across axles, but ain't nobody that crazy, right?). As long as your wheels clear your brakes, you're generally fine, noting that substantial changes from stock rolling diameter will influence the accuracy of your speedometer.
My E43 came on 20" factory option rims (245/35R20 front, 275/30R20 rears - missing from the table above), the factory standard 19" setup for it is 245/40R19 and 275/35R19 (the latter is actually better in terms of lower front to rear variation). I am going down to a 255/35R19 square setup, which has a slightly larger rolking diameter than the stock options, but because I am going square setup, the 4Matic system will be more than fine.
Your wheel bolts don't centre the wheel on the hubs, that's the job of the centre bore.
