Wobbly Cooling Fan - 2013 C250 Mercedes
Old Jul 11, 2023 | 12:48 PM
TBAE1962's Avatar
2013 C250 Sport
Hello! Hoping someone can help me identify what might be the cause of why my cooling fan intermittently comes on, wobbles, makes a loud rattling noise -- then turns off. The shroud is tight but the fan itself is loose. Also: any suggestion on repair?
See attached video
File Type: mov
Old Jul 11, 2023 | 06:47 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W204 forum...
Old Jul 11, 2023 | 08:02 PM
meazz1's Avatar
C250 2013
It sounds like the motor on the fan is going bad. Change it before it stops and cause engine to heat up.
Do a visual when it wobbles.
Old Jul 12, 2023 | 12:51 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
It looks like the bushings on the fan motor are bad. Shroud, fan, and motor are replaced as a unit. There are multiple application dependent types, so get part number off the original and replace with same or recommended replacement. Online sources are less expensive than dealers. Use sources where correct parts can be found by entering VIN.
