Front SAM
Old Feb 26, 2024 | 08:38 PM
benro1974's Avatar
2009 C300W
Front SAM
2009 c300
Can the front SAM be totally failed even without any obvious corrosion or water damage?
I have multitude of symptoms that have been progressively increasing.
Left front running light staying on.
Then cranking but not starting.
Then OBD2 scanner won't turn on.
Then not crankning.
Then radiator fan coming on at full speed.
Also checked the pre-fuse box and all fuses are good.
Old Feb 27, 2024 | 03:10 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
long list of bisted essentials
Originally Posted by benro1974
2009 c300
Then not crankning.
The beauty about these very sophisticated cars is modules can disfunction in cascade. Such as SAM helping crash networks.
To be honest it works almost right most of the time.
You can go ahead and reboot your car computers
you can scan your car for faults if not networking is seriously bad.... we can unplugg some crazy network branches at the front door threshold busbars.
Old Feb 27, 2024 | 08:14 AM
TimC300's Avatar
For the front sam there could be an issue on the circuit board that wont be easily visible just looking at it with the top cover off. Here's an example:
For the OBD port you said you checked the fuses but I would check them again. I think the front is fuse# 16, and the rear is fuse# 73.
Front
Rear:
Are there any signs of water getting in the car? Ive seen where water damaged the front sam. I just read a post where someones obd port wouldn't work and turned out to be water got in the car down on the carpet near the drivers side door and and got in some connectors.
Old Feb 27, 2024 | 02:04 PM
benro1974's Avatar
2009 C300W
Yes, I looked at the circuit board and it looks perfect.
I am going the look at the connectors by the driver's side door. I do think it is water related. We get a lot of rain in Hawaii and the windshield wiper motor cover drains get clogged.
QUOTE=TimC300;8930917]For the front sam there could be an issue on the circuit board that wont be easily visible just looking at it with the top cover off. Here's an example:
Front
Rear:
Are there any signs of water getting in the car? Ive seen where water damaged the front sam. I just read a post where someones obd port wouldn't work and turned out to be water got in the car down on the carpet near the drivers side door and and got in some connectors.[/QUOTE]
