Strange sound coming from somewhere near glovebox
Not correlated with road smoothness or engine rpm, but does appear only above somewhere 50km/h. No correlation with speed either.
Giving the sound I suspected blower first, tuned off A/C - sound still there, suspected command fan, turned off command - still there.
Needless to say, checked/removed everything from glovebox that can produce any sound.
Going to mechanic is likely not good idea now since sound is reasonably quiet and barely can be heard in city centre.
Any ideas what can it be? Sorry for vague description.
To really rule out the blower motor have the car running with the heat on then open the hood and remove the plastic box above the battery, you should be able to see the blower motor and hear if any noise is coming from it.
Turning A/C off allegedly turns off the blower (if ECU doesn't keep it running for residual cold) but the noise still stays.
wow! You really have no heat function? That makes logical sense, but not logistical sense to me. But I’m not Mercedes.
Tim’s recommendation still holds, however.
For the same reason I have different A/C package compared to say european cars. It is called something like strong A/C. Makes huge difference in tropics compared to europe - imported cars
