C220 CDI 2013 fluid leak
1 Post
C 220 CDI 2143cc Diesel Estate Tiptronic 2013 model
Hi guys just joined the forum as I have purchased my 1st Mercedes C220CDI 2.2 auto 2013 model.
I have noticed looking directly down from the slam panel what appears to be some sort of cooler with a green type oil/fluid leaking.
Question is what is the part and what could the fluid be?
Thanks for any advice.
I dont have that engine so im just guessing its coolant. I thought later models use the red coolant, my 2010 uses the blueish coolant. I looked around and maybe this diagram shows the parts?
2013 w204 c250 coupe & 2001 Dodge Ram 2500 24v Cummins
Based on the color of that fluid, that's the color of the transmission fluid most cars from this generation use.
I tried searching that part number A0995002800, but couldn't make out the last four digits so I guessed. Came up as a radiator/intercooler.
Ant
The 2800# was coming up with a large radiator. I think its more like 0995002300- Transmission oil cooler.
I think the hose/fittings are leaking. But hard to tell just from the photo.
1 Post
Hi many thanks for your input the actual part number is A0995002300
I am going to clean it all off tomorrow and see if I can see exactly where it is leaking
The cooling hose couplings look interesting I’ll check them out also.
antboii (03-14-2024)
But it's either trans fluid or coolant being, blue in color.
I wouldn't be surprised if the plastic coupler cracked/is leaking from a hard hit or vibration.
Good luck, keep us posted.
Ant
Try and figure out what type of fluid it is before you go and take it apart.
If it's coolant and seeing it is a very low point on the system, you minds well just do a full flush because you are going to drain all of it out basically.
if it's trans fluid, that needs to be pumped in from the trans pan.
Identify fluid first then go from there.
Ant
https://www.mbdecoder.com/
Ant
