[W204] [180 CDI] 722.9 Transmission Issues + Error Codes from Xentry
There is no "Check Engine" light even though there are error codes (I'll show you guys in a bit) and if you turn off the ignition, remove the key and wait 10 seconds the PRND symbols will appear again and the car will work as normal for a few more minutes. Due to this being random, it's likely an electrical issue.
When I started having this problem out of the sudden I decided to go do a transmission oil change - It went well - Followed WIS procedure - Car started drove as normal and then randomly... Same problem.
• Transmission: 722.966 (PLUS)
• Transmission Oil Type: Blue (9L)
• Certification: MB 236.15
• Kit: Meyle 0141371107
I've checked the wiring going from the TCM module (Which is a VGS3, I can communicate with it without any problems using Xentry) and all seems good and secure, cleaned them a bit and covered a few exposed wires... Issue still happening.
All the error codes from Xentry (After clearing them and letting the issue happen again randomly):
• Module: N3/9 - Motor electronics 'CDID3' for combustion engine 'OM651' (CDI)
• Fault(s): U010187 Communication with control unit "Transmission" has a malfunction. The message is missing.
• Module: N62 - Parking system (PTS)
• Fault(s): C44700 Implausible data were received from the central gateway. / C10100 Communication with control unit "Transmission" has a malfunction
• Module: N30/4 - Electronic stability program (ESP®)
• Fault(s): C257200 No CAN message was received from control unit 'Combustion engine' or 'Transmission'. / C322000 No CAN message was received from control unit 'Transmission'. / C258600 No CAN message was received from control unit 'Combustion engine' or 'Transmission'.
• Module: A1 - Instrument cluster (IC)
• Fault(s): U010100 Communication with control unit "Transmission" has a malfunction.
Any help is appreciated, I'm suspecting the problem is the CANs (Voltage Inverter, Distributor Blocks, etc.), there was no water damage...
Last edited by DiogoBett; Jul 4, 2024 at 06:08 PM. Reason: Added Fault Code + Corrected Grammar
You might want to run through the tests in XENTRY for each of those controllers.
VGS still shows no faults, but I've noticed low voltage.
Also here's the low voltage:
I'm completely at a loss of what the issue is... I've got to check the CANs under the driver seat this weekend.
I seem to have had the same problem as I just posted a thread on it.
I ended up changing the conductor plate (pre-coded) but now it wont indicate the gear what so ever and I am a little lost what to do next.
My car is a 2008 C63 115k miles with a VGS 2 conductor plate. But strangely I have plenty of TCM codes as below :
1405 : Communication with control unit "Transmission" has a malfunction.
U1108 : No CAN message was recieved from control uni "Engine control system"
U0155 : CAN communication with control unit "A1 (instrument cluster)" has a malfunction
U0415 : The CAN signals sent from control Unit "Traction System" are incomplete
U0141 : CAN communication with control unit "N73 (electronic ignition lock control unit)" has a malfunction
U0126 : CAN communication with control unit "N80 (steering column tube module control unit)" has a malfunction
U0164 : CAN communication with control unit "Air Conditioning" has a malfunction
U0121 : CAN communication with the traction system has a malfunction
U0100 : No CAN message was received from control unit "Engine Control System"
U0103 : No CAN message was received from control unit "N15/5 (Electronic selector lever module control unit)"
Sorry I haven't updated this in a while.
The problem was the processor of the TCM:
- P0613 - The processor in control unit "Transmission" has a malfunction.
I've given them all the information of the existing VGS3 plate that's on my car via Xentry Diagnostics like VIN, CVN, SCN and EHS and they've virginized and programmed it into a repaired / upgraded VGS3.
I'm not going to pay 1000€+ for someone to program this, so I bought a "Pre-Programmed". I wish mine was a 722.6 (Plug & Play) model.
I just need to do the adaptation, which I can do using Xentry Passthru, but I haven't had time to drain the fluids and replace it yet.
LOL, the 722.6 5-speed makes me jealous when it comes to fixing the tranny.
Honestly I haven't talked with anyone here about programming one, the 1000€ mentioned is a quote someone was given at a Mercedes dealer, but I don't even have one on my island.
Hopefully it works
I finally had time to fix the issue with my car.
- Bought a Pre Programmed VGS3 plate from ebay (From USA) by giving all the old conductor plate's information;
- Drained the transmission (Reused same brand new oil);
- Took out the valve body + the old conductor plate;
- Separated the valve body from the old plate;
- Put the Valve Body together with the new plate;
- Attached it to the Transmission again;
- Plugged in the TCM connector;
- Used Xentry PassThru to Disable Transport Protection, Personalize and Activate plate (Offline);
- Teached the TCM how to shift gears;
- Put the Transmission back together and Refilled it (Filter, Oil, Pan, etc.)
- Car was shifting rough, had to do Upshift Adaptations;
