W204 HID Retrofit
Old Nov 4, 2018 | 09:24 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
W204 HID Retrofit
Hey guys,
Just a few questions on hid retrofit
1) I think I have to drill the caps. Do SLIM style HID kits prevent the need for drilling? What is the benefit?
2) Do HID retrofits require an error cancellor/separate attachment? Not just for a particular brand, in GENERAL for w204.
I see some brands w/ reviews do not look like they need a cancellor. So does it depend on brand then?
Any tips or tricks for installing them? Drilling holes, mounting, etc?
Old Nov 4, 2018 | 10:08 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
You're going to still need a canbus kit (what you're referring to as cancellers) regardless. And you'll need to drill holes to feed wires. Slim ballast isn't going to make a difference. People shouldn't stuff their ballast in headlight housing as ballast relies on engine airflow to cool.
Old Nov 5, 2018 | 02:17 AM
VeronSvn's Avatar
W204 facelift
I had same dilema as you.
I ended up buying new headlights (Depo) with projector. But Depo projector sux (despite putting "slim" xenon kit).
So I took apart the headlight and installed bi-led i-lens projector and it's super.
Old Nov 5, 2018 | 10:08 AM
Adi-Benz's Avatar
Thanks Mike. Does this mean some have integrated canbus? I see on some of these kits the reviews (with other C300's) say that they worked error/blinking free. Btw you still have your C300?
I have prefacelift which have halogen projectors. Swapping out projectors is a bit too much work than I'm looking to do. HIDs should be enough for me as it should be an improvement anyways.
Old Nov 5, 2018 | 11:22 AM
AZN Optics's Avatar
So it just depends on design. Some kits have the canbus canceller embedded within the ballast and some have it external. The better design is external because the canbus canceller is basically packed with giant resistors and should be the highest heat generating component. By separating it from the ballast, you should enhance the life of the ballast. However, for ease of install, some people are less intimidated by having one less component piece they have to deal with. It's also a cost savings for the manufacturer by integrating the canceller into the ballast as they don't have build out the extra housing component and wiring for the kit.
Old Nov 5, 2018 | 11:39 AM
Adi-Benz's Avatar
Sounds good.
I'm thinking ballpark 6k, but I do like a hint of blue so I'm curious, will 8000k be brighter than halogen still? I would assume 6k would be the sweet spot with best brightness though (non yellow)
Old Nov 5, 2018 | 12:07 PM
AZN Optics's Avatar
5500k (pure white) has slightly higher lumen compared to 6500k (white with a slight bluish hue).
Old Nov 5, 2018 | 09:38 PM
Adi-Benz's Avatar
Thanks! Any difference/preference between the AC and DC for our models?
Edit: Seems like AC is more reliable so AC it is
Old Nov 5, 2018 | 10:20 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
...have to drill the caps...
There is a feed-through for the stock Halogen bulb. Can we use that to avoid drilling hole on cap? I'd imagine it's a very difficult access without taking the entire light assembly out.
Old Dec 20, 2024 | 08:54 PM
daast's Avatar
w204
I'm thinking about doing the same for my headlights since the projector is trash.
I know it's been many years, but do you remember if you had to modify a lot to change the projector?
Old Dec 20, 2024 | 11:55 PM
TimC300's Avatar
I just replaced my drivers side aftermarket hid ballast due to it failing. I have the Innovited can-bus 35w kit, installed Jan 2021 and they worked perfectly until the end of Nov this year. Coincidently my yearly car inspection sticker expires this month. I ordered a replacement set to instal;l and was waiting to get them to go get my car inspected. But after wiggling the wires the light started working fine again,. I stopped in to get my car inspected, the guy drove it in and i saw the headlights light fine for the testing, drove it out with a new sticker. I get in the car and start it to drive away and the bulb out message popped up. I got lucky. Went right home and replaced the ballast, now its working fine so far.
I just found it funny how right as my sticker is due something seems to always pop up.
For bulbs I have Morimoto XB H7-B 4500k. The Innovited ballast has everything wired together. Very simple to install. Nothing gets hot, just warm.
Old Dec 22, 2024 | 06:24 AM
VeronSvn's Avatar
W204 facelift
all I had to drill the mounting holes in existing socket. Because led projector was a lot shorter, I had to mount it on "front" part of mount. Everything else was untouched.
Old Dec 23, 2024 | 11:25 PM
TimC300's Avatar
I was looking around and came across Morimoto bulbs at Lightwerkz for $25. With the savings code it came to $32 with shipping. I think my current ones I paid $50 + shipping. I figure why not have a spare set. They are the same ones I have currently installed, the H7B-4500k.
