2011 C300 4matic Sport ESL - no power
Old Jul 31, 2024 | 11:29 AM
richbark's Avatar
c300
It appears my ESL has died in the unlocked position. I was able to get it out of the car. Pulled it apart and installed a new motor (thinking motor was shot). Re-connected ESL to the Harness and still not working - no clicking, no buzzing, no motion on the lock. I have tried searching for pin out for the connector so I can check for power at the ESL. Does anyone know what the pin configuration is for the ESL plug?
I am OK with getting an emulator, but want to verify power to the ESL first.
Thank you in advance. Any help is much appreciated.
Old Jul 31, 2024 | 06:52 PM
TimC300's Avatar
When I search "Mercedes W204 ESL wiring diagram" this came up:
Old Jul 31, 2024 | 10:33 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Don't loose your marbles... use the scanner to query live status from modules.
Unplugging live security modules hurts more than it helps.
A good scanner will help you understand what's going on... without that, we are blind.
Old Jul 31, 2024 | 11:30 PM
bv9900's Avatar
200cdi w204
The positive of the esl is the same as the ezs I believe. Get a diagnosis, your esl will be blocked and no longer valid. Disassemble your EZS and take it to an electronic workshop to program an emulator.
Old Aug 1, 2024 | 08:07 AM
richbark's Avatar
c300
Thank you everyone. The diagram and other info was very helpful. I have decided to go the emulator route. Pulled ignition and key, and overnight shipped to vendor. I will post update when unit comes back.
Old Aug 5, 2024 | 08:06 PM
richbark's Avatar
c300
UPDATE! The emulator that I ordered came today. Installed it and the car started right up - no issues. Service from the vendor I chose was GREAT! 1hr 20m and car was all re-assembled and driving. I do not want to violate any advertising rules here, but if you want to know what vendor I used for the emulator, private message me and I will provide details.
Thank you to all who helped.
Old Aug 5, 2024 | 08:29 PM
zabok's Avatar
C300 Luxury Sedan 4matic
Hi Richbark,
I have the same issue with ESL.
Would you mind sharing the details about Emulator and the Vendor?
Thank you
