P2279 need advice
Runs fine. Car was at dealer for subframe replacement and they believe the p2279 is a leak at the intake.
I’m skeptical on that.
I’d like any opinion as to a probable cause and course of action on a repair.
Thanks in advance!
what's code p2279?(Keep your 4Cyl. Turbo oil clean on early 5kMi schedule).
You mentioned intake oil swamp from high blow-by overheated oil... is intake sensor dirty or cooked up like the leaky CPS ??
Read intake (MAP/MAF) sensors with engine stopped for reference.
XENTRY has step-by-step troubleshooting procedures for diagnosing and repairing fault codes, such as P2279. Additionally, BenzNinja can remotely access your car and help diagnose problems if you get a membership in his club.
Secondly, get a Mercedes specific scanner, such as the LAUNCH Creader Elite 2.0 BENZ for about $160 on Amazon. It's compact and can be kept in your glove box or other storage space. Generic OBD scanners are worthless when it comes to Mercedes. I keep a LAUNCH Creader scanner in the rear SAM (fuse cluster) location in the trunk. You should never leave home without it.
Your engine is ingesting extremely hot oil that cooked PCV O-ring all the way at intake.
How is that?
The limited engine oil effectiveness (viscosity + solenoid) is burning oil on overheated pistons. Your 4Cyl. engine has a known appetite for pistons.
Some of the burnt oil gets stuck in piston rings, some gets vaporized into dirty intake.
The super heated pistons cause extreme heatsoaks that cook all plastics attached to engine heads. Specifically the cam sensors that send oil into ECU on its last day.
There's more goodness related to extreme heat... I personally think it's overrated to save gasoline with limited oiling when it cause so much ridiculous chaos and poor performance.
Have a look at this thread where some of us have cancelled extreme heat for free with better oiling. I believe this can extend your engine life many folds but may also kill it during normal cleaning. Loose junk goes through filter bypass valve to plug-up squirter lines: piston fragmentation.
Your engine has the faults giving you clues... now is time to act!!!
At the very minimum do chance oil at 3 to 5kMi.... not 8, 10 or 12kMi.
Use a clean API-SP rated oil...
Mobil1 now even has a OW-40 SP available.
Better oil viscosity yields better cooling that your engine is desperately asking for.
