"Rear left/right seat backrest not locked" after SAM replacement
Old Jan 2, 2025 | 11:24 PM
uchu47's Avatar
C230 W204
Replaced rear SAM module after original one went faulty due to accumulated water. Couldn't get exact module for my car so got a bit newer 2nd hand one. Now every time door is opened I am getting errors "Rear left/right seat backrest not locked". My car doesn't have sensors at backrest.
Is there any way to make it ignore those errors?
Thinking of putting hard wire to related switches in SAM module to emulate the rear seat sensors.
Old Jan 3, 2025 | 06:12 AM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
First i would compare the old sam to the new one and see if the fuse layout matches. If not try removing or adding fuses where needed.
another possibility would be to find the wiring diagram and see if a fuse covers those locks and maybe remove that fuse.
After all that it's possible you just need the new Sam programmed to work on your car.
Old Jan 3, 2025 | 12:03 PM
TimC300's Avatar
May be able to disable it.
This is what I came up with when searching around:
Old Jan 28, 2025 | 12:24 AM
uchu47's Avatar
C230 W204
thank you @TimC300 ! I found the same topic by search. And after disabling the option "DLM_enable" error is not showing up anymore.
Old Jan 28, 2025 | 11:11 AM
JettaRed's Avatar
Veteran: Army
Curious, but does your rear seat backs fold down? If so, then you do have sensors.
Old Jan 28, 2025 | 08:28 PM
uchu47's Avatar
C230 W204
That's actually a good question, all this time I thought there is no fold (or I just don't know how to do it). Likely it doesn't fold.
Old Jan 28, 2025 | 09:42 PM
JettaRed's Avatar
Veteran: Army
If they do, there are levers within the trunk at the top.
