2010 C300 — Intermittent Coolant Warning + Fan Codes (Need Input)
Old Aug 28, 2025 | 10:53 PM
bobb00's Avatar
Hello,
I have a 2010 C300 (M272, 141k). Car runs great overall, but I’ve been chasing two issues:
  • White Coolant Symbol on cluster - comes on intermittently while driving (even fully warmed up). Goes away on its own after a few seconds. Coolant temps are steady on the gauge around 85–95°C, never overheating.
  • Cooling fan behavior - once after parking, fan stayed running for ~30 min with engine and A/C off. Eventually shut itself off after starting car. Normally it only runs with A/C on, which is correct.
  • A/C symptom - when the white coolant symbol pops up on cluster, the A/C air gets warmer. As soon as fan cycles normally, A/C is cold again.
  • OBD codes -
    • 0694 “Fan short to ground”
    • 2362 “Fan power supply malfunction”
      Codes clear but return while driving.
Would appreciate some feedback on this, thank you.
Old Aug 28, 2025 | 11:02 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Fans do burn out. Mine went at 198k miles. My most noticeable symptom was the needle on the cluster bobbing up and down every 5 seconds.
Old Aug 28, 2025 | 11:05 PM
bobb00's Avatar
Can I just get a junkyard one and throw it in or an aftermarket brand new?
Old Aug 29, 2025 | 10:28 AM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
Rock auto and Amazon sell fans. They ain't cheap but not factory price. Easy swap no special tools needed
Old Aug 29, 2025 | 07:55 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Check eBay. The production sticker on our fans is clearly visible. I got one that was made in 2017, 9 years after my car rolled off the line.
Old Aug 29, 2025 | 08:19 PM
TimC300's Avatar
Those two codes seem to be the same. Wonder if it can be tested with an obd scanner.
