Passenger wiper intemitment and not aligned
Old Oct 21, 2025 | 03:26 PM
cdt808's Avatar
Ok - I have searched the forums and read lots about wipers not working (for various reasons) or juddering on the wimdscreen, but my issue is neither of these.
Since having my windscreen replaced, my passenger wiper works..... sometimes! It will be fine and then just stop working, then a few minutes (or hours) later it starts up again! It seemed to start when the two wipers collided in the centre of the windscreen (so presumably something happened to them) and has caused the passenger one to now move far too far down, so it clunks against the car at its lowest point.
Anyone come across this before or know where I can start looking to try to fix it? any help would be REALLY appreciated
Old Oct 21, 2025 | 03:27 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
There is one motor for both wipers. Who ever did your windscreen did not properly re-connect your wiper linkages.
Old Oct 21, 2025 | 03:39 PM
cdt808's Avatar
Would that cause it to work sometimes but not others? It would make sense if one worked and not the other, but it does work sometimes....
Old Oct 21, 2025 | 04:42 PM
Could be something not tight enough...this is an image of what just about every MB does for wipers (variants of this). Something is loose. Probably the arm itself - you can take off the plastic shield and try a 14mm socket on it to check if it is tight.
Old Oct 21, 2025 | 05:04 PM
cdt808's Avatar
Many thanks for the replies chap - much appreciated. I'll take a look tomorrow and see if everything is done up properly
Old Oct 21, 2025 | 05:14 PM
TimC300's Avatar
Did they remove the wiper arms? Im not sure what a windhshield replacement entails.
if they were removed they probably werent put back on properly. Have to go ahead and remove everything they worked on then reinstall it properly.
Old Oct 21, 2025 | 06:17 PM
meazz1's Avatar
C250 2013
You would have better access to the windshield with the arms removed.
I replaced the entire wiper motor and the linkage few yrs ago.
I think the arm is not pushed in to stud and bolted correctly.
Old Oct 21, 2025 | 08:20 PM
TimC300's Avatar
Lets see what the manual says:
Old Oct 21, 2025 | 08:24 PM
It is going to be an untightened wiper arm.
Old Nov 17, 2025 | 02:44 PM
cdt808's Avatar
Sorry for the late update.
Yep - you were right, whoever put the arm back on after changing the windscreen did not do the nut back up tight enough (the central one that drives the arm) and it kept lifting and has worn the grooves on the arm completely away, hence the slipping. New arm ordered but for now some electrical tape on it and tightened it up properly and its working ok
Many thanks for the help and image of what it looks like under there
Old Nov 17, 2025 | 03:23 PM
You know you are going to send your part bill to the folks who replaced the windsheild.....glad it all worked out.
