Repeatedly blowing starter fuse
The starter is a simple circuit with very few items to disconnect for testing.
Next was diconnecting all the plugs from the SAM and seeing if it blows. It did not which was supposedly to suggest that the SAM was bad. The SAM was replaced but yet the fuse blew when key was turned. Next step was to unlug the 2 connectors to the ECU and see if the fuse blows which it did not which tells me there is a short in the wiring harness. I am using WIS to try and locate the wiring diagram for the ECU and fuse 7 branch so that I can measure resistanc from each wire to ground. I havent exactly gotten the hang of using WIS and thought I would check on here to see if anybody could guide me to where I need to look.......please
In WIS, locate the starter diagram that's actually near the main battery + Alternator.
The circuit you're dealing with "starter signal" has very few connections.
It will soon be working - No more guessing with a diagram.
Done under 30mn, likely free fix, no parts .
1- Post the diagram here...
2- Disconnect both end of "starter signal" circuit
3- test if it is shorted to GND ...( likely yes) ?
use a test-light or a DVM.
(Do not run down your battery low)
Hopefully this is the diagram you are referring to. I know that M1 is the starter, G1 - battery, and G2 is the alternator. I am surprised to see that the red power wire goes from the starter to the alternator. Anyhow you are saying that I need to test the starter signal wire at both ends, correct? I know one thing that has been tested as good already was continuity from the end of the signal wire to the pin in the plug that connects to the front SAM box.
I have been keeping a battery maintainer on so that battery doesn't go low.
is this your shorted starter command line ?
if yes disconnect from X26 junction and from starter then test for short circuit to GND.
This is a "Violet-White stripes" single wire from F-SAM direct to stater relay, not shared.
direct SAM output, not shared.
I think we can ignore the power side here... correct?
Starter battery power cable comes straight from the battery. the starter post also has a cable that goes to Alternator to collect battery charging power during run time.
What Starter fuse is blowing... inside the SAM ??
SAM has a small built-in relay that controls the line we are looking at...
Physically check that harness is not kissing the exhaust line on the way to starter.
Then went ahead and tested end of starter wire to the pin in the connector plug those goes into the SAM, result was the same.
- Outside/After the SAM/X26 ?
- Inside/Before X26 ?
However, I just realized that I am not getting the constant 12V at the pin 30 under starter relay in the SAM. I checked that 12V is showing on all the studs of the Prefuse box. 3 in total. Should I only have 3 of those to check is my first question?
Disconnect X26 to find out if your short is before or after X26 junction.
Then go from there.
