Persistent Cold Start Idle Drop Error After Timing Chain & Oil Pump Issues – 2011 C18
Old Apr 21, 2026 | 06:29 AM
seainn99's Avatar
Mercedes Benz C180 1.8CGI Avantgarde
Hi everyone,
I’m dealing with a persistent issue on my 2011 Mercedes C180 1.8 CGI Avantgarde (M271 engine) with 350,000 km.
About 2 years ago, the engine started making timing chain noise. We replaced the chain, but the noise came back. It was replaced again under warranty, but the issue persisted. After that, we imported original parts from Germany, including the timing chain and camshaft adjusters (VANOS units), and installed them.
Later on, the engine was disassembled again and we discovered that one of the oil pumps had seized. Since a brand-new original part wasn’t available at the time, we installed a used oil pump. About a year later, the oil pump chain guide broke, and the engine had to be opened again. This time, the oil pump was replaced.
However, throughout this entire process, one issue has never been resolved:
  • On cold start, the engine idles at around 1500 RPM, then drops to normal idle
  • As the RPM drops, the check engine light comes on
  • If the idle is set slightly higher than normal, the error does not occur
  • In warm weather, the issue is rare or doesn’t happen
  • In cold weather, it happens consistently
  • Sometimes the error stays, sometimes it disappears on the next cold start
Additional info:
  • Throttle body is new (Bosch)
  • Adaptation/calibration has been done with original Mercedes diagnostic tools
I have also attached a photo of the error code for reference.
At this point, I’m not sure if the issue is related to oil pressure, timing system tolerances, or sensors.
Has anyone experienced a similar issue or can suggest what to check next?
Thanks in advance.
Error Codes: P006800,P001177,P233722
Old Apr 21, 2026 | 10:44 AM
Highline-Autos.com's Avatar
SPONSOR
2001 E55AMG
Is the chain maybe not tensioned correctly?
Trenton O. Gibson
tgibson@highline-autos.com
Highline Autos
Direct: 602.909.9216
Office: 480.348.0777
Old Apr 21, 2026 | 10:50 AM
seainn99's Avatar
Trenton O. Gibson
Highline Autos
Thanks for the suggestion.The chain tensioner and timing have been checked.
If it was not set correctly, wouldn’t it cause constant chain noise or a continuous issue rather than only on cold starts?
Old Apr 21, 2026 | 11:28 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
The trouble codes point to 3 distinctly different failures, which you have probably seen on your scanner descriptions.
-Mismatch in information received from air flow and throttle position sensors
-Camshaft timing errors
-Combustion knock sensor cylinder 2
Since increasing idle speed remedies errors and the throttle body is new, possibly the MAP (MAF?) sensor is at fault.
Old Apr 21, 2026 | 11:35 AM
TimC300's Avatar
Unfortunately I dont have access to detailed info on the M271 engine. I'm getting some of my info from M272 manuals.
For the fault codes I come up with intake cam position off, implausible air mass to throttle valve and self adjustment of mixture erratic?
If the fault is for the intake cam can you see its position on your scanner? Reading upon start up then at idle.
Old Apr 21, 2026 | 12:04 PM
seainn99's Avatar
Thanks for your input.
I understand the different fault categories, but since the issue mainly occurs on cold start and disappears with higher idle, it seems more related to cam timing behavior than a sensor issue.
If it were MAP/MAF, I would expect the problem to be consistent rather than dependent on temperature and RPM.
So I’m leaning more towards a timing control issue (possibly solenoid/magnet related).
What do you think?
Old Apr 21, 2026 | 12:08 PM
seainn99's Avatar
Thanks, that’s a good point.
Unfortunately, I don’t have easy access to live data right now, as the scan was done by my mechanic.
I’ll see if I can get those readings, but it may take some time.
Old Apr 22, 2026 | 01:52 AM
Odd Piggy's Avatar
I do think the knock sensor issue is incidental to whichever one of the other is at fault. Your point on the adjuster solenoids when cold could be the point. I also thought about the locator pin on the adjusters being bent and not latching properly from that, but checking that would take going into them again, possibly for no gain.
Since it is only on a cold start at low temperatures, it could also be something in the open cycle system where many of the sensors are ignored. Those problems are very hard to find.
Old Apr 22, 2026 | 03:53 AM
seainn99's Avatar
That makes sense.
I did some research and found that in cold conditions, if the camshaft magnets don’t actuate properly due to low oil pressure, it can cause this kind of issue. It also seems to match the behavior, since increasing idle RPM makes the problem disappear.
Is there a way to check the camshaft magnets without removing too much? For example, if there is oil inside the connectors or around the magnets, could that indicate a problem?
Old Apr 22, 2026 | 01:01 PM
Odd Piggy's Avatar
Oil inside the connectors is definitely a problem. It has to be addressed because oil can migrate along the wiring harness. The oil itself can damage every plastic connector it touches and can even get into other sensors and the ECU. The additives and contaminants it carries are even worse. If you have oil in the magnet connectors they need to be replaced and the cam position sensors, the crank position sensor, and the ECU connector need to be checked.
Old Apr 22, 2026 | 01:25 PM
seainn99's Avatar
Thanks, that’s very helpful.
I’ll first check the connectors myself to see if there is any oil present. Then I’ll have the camshaft magnets inspected and get back to you with the results.
The car gave the error again today, so I’ll also scan it again to see if there are any additional fault codes.
Old Apr 23, 2026 | 12:52 PM
seainn99's Avatar
Quick update:
I scanned the car again after the error came back. This time I got:
  • P254009
  • P006800
The issue still behaves the same:
  • Happens on cold start when RPM drops
  • Does not occur if I increase idle or give slight throttle
  • Much less noticeable in warm conditions
I will check the camshaft magnet connectors for oil and report back with what I find.
Old Apr 23, 2026 | 04:08 PM
TimC300's Avatar
For the P254009 i come up with something about the low side fuel pressure.
With the scanner what do you see for the fuel pressures? With ignition on, then start-up, then idle, raising RPM's.
