View Poll Results: Any problems with your new C-class W205 Mercedes Benz ?
Yes
280
63.49%
No
161
36.51%
Voters: 441. You may not vote on this poll
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
- Mercedes-Benz C-Class AMG: Common Problems
Important information to help you understand your Mercedes-Benz
Mercedes Benz C-class W205 Problems Malfunction What Is Your Experience ?
#401
2015 C300 RWD Sport Premium
I have the RWD. I doubt its the tires I'm hearing against the pavement. I realized the scraping is only during sharp left turns where you can longer turn the wheel. I was also going no more than 5mph. This weekend I'll get under it and do a visual inspection. Probably end up dropping it off for a more detailed look.
#402
This is my 3rd AWD car. I was basically flooring the car and making a hard left so it sounded like the tire was scraping the pavement which could be just stutter but the sound could be misinterpreted to be scraping the wheel well. This is my first experience with run flats and so far I'm not impressed with quality of the ride. It may or may not have had anything to do with AWD as much as it could be due to the run flats.
#403
1 Post
2015 C400 4matic W205
I had previously reported that the exterior handle LED lights had stopped working on the rear left and rear right handles within 1 week of each other. The parts were initially on backorder. The dealership then ordered the wrong parts. Then correct parts were also on backorder. Eventually the rear lights were fixed. 3 months later the driver side handle light started turning purple and a week later it stopped working......there is obviously a systematic problem here. A normal LED lifespand is 70,000 hours! and these lights are only on at night when I unlock the car for maybe 30 seconds. Maybe they have been on for a total of a few hours. Definately not more than 10 hours. Last time I had brought the car in, they were trying to diagnose the issue, they had mentioned that the lights are getting voltage even though the lights aren't working. I'm guessing there is a voltage regulation issue......I wonder how long it will be before the front passenger light goes out as well, and if the fix that the dealership provided is just a superficial fix or actual deals with the source of the problem.....only time will tell.
#404
It just keeps getting better...
So I dropped the car off for the squealing brakes, door handle LED, sagging sun shade and rattling speaker to be repaired. 3 days later I get it back and they fixed the door handle and only repaired the front brakes. They claim there is no problem with the sun shade, the speaker rattle is the same in all the cars they checked on the lot and there is a bulletin out on that problem but no fix. Advisor said it may just be a software update. They were only able to reproduce it when making a Bluetooth phone call. So I am going to see if only fixing the front brakes will eliminate the brake squeal problem. The fix for the brakes was a new fitment kit for the pads. As far as the rattling noise in the speaker is concerned it is mostly only while making a call or listening to talk radio. I guess I'll have to live with it for now until the find a fix. This has been a thoroughly disappointing experience.
#405
My frustration with the problems my own car has had is not that there were problems, but rather the lack of timely fixes. Problems with the door LED's, inconsistent Keyless Go operation, rear bumper fit, the loose sun shades, brake noise, and wind noise are well known and have been around since production started, but cars are still being produced with those same problems. The MB-Tex issue is the only problem I know of that had a TSB and a factory authorized fix. The rest of it seems to be up to the individual dealers to figure out, and that seems to be more trial and error than anything else.
I really wish MB was more proactive about all this stuff. My patience has been sorely tested and my confidence badly shaken ... not an ideal way to start any new car experience.
#406
We have a W205 c220 sport estate
Our complaints so far:
DAB radio seems to repeat itself when first switched on
Our rear parcel shelf guides broke (both sides)
Internal light doesn't come on when you switch your engine off (keyless go) but does if you use the key
Wind noise
Passenger headrest motor failed
Carpet trim came lose
Traffic/traffic along route seems to have stopped working on GPS
Internet radio not working
Wind noise
#407
So now that a few guinea pigs have had their seats changed, I am going to bite the bullet and make an appointment to try and get the issues I am having with my C300 taken care of, hopefully all at the same time, and correctly. They are :
1) Bleeding Seats
2) Rear Bumper Misalignment
3) Driver Door Misalignment
4) Squealing brakes
5) Excessive Wind Noise at Driver Door
1) Bleeding Seats
4) Squealing brakes
1) The plastic trim between the pano roof glass and the car body has broken or come loose on the driver side toward the rear window. I fiddled with it to try snap it into place, but no joy.
2) This one is more concerning. I am hearing a noise from the passenger front end when I move the steering wheel side to side driving. I also hear it when going over a speed bump. Perhaps the front CV? It is more of a banging rather than a clicking that you would associate with a CV though. Interestingly, I don't hear it when the car is cold, only after driving for a bit.
Will add it to the list. Nothing has been addressed yet, the dealer has been waiting for the seat parts for almost 1.5 months.
I tried to make a video of the noise as I was nearing my house this evening. It is barely audible in it (much louder in person), but you can kind of hear it as I saw the wheel back and forth.
#408
W205 C250 Sedan
I also noticed the plastic trim fitment is not ideal between the pano-glass and the body. It seems to be sticking out a lil bit. Every time I wipe the car the cloth would get caught on it.
#409
Clutch
Well c220 manual only six months old and I have had to have new clutch and flywheel fitted. Took dealer a week to find the problem it was like a misfire and they thought is was contaminated fuel also now they have fixed that the park assist does not work so back we go
#411
Slow turns at almost 90 degrees for you? It's a dulled "knock knock knock" only at certain degree turns; also inconsistent. I've usually noticed it turning into my driveway. They initially thought they knew what the issue was, had to do with fluid transfer on 4MATICS, but the soft fix didn't seem to work this time. Thus bringing it in again next week. I'm just glad they were able to replicate the issue, as I was previously.
Same scenario on the noise for you?
#412
Some minor issues with my replacement C300. Yesterday, while driving, I heard three beeps, and then Agility went into Sport mode. Nothing else happened, so I have no idea what this was about.
Two minor trim issues. The plastic piece that goes from under the dash to the sill, on the driver's side, has popped out of its groove. It is tight, and I can't move it or reseat it, so I'll leave it until the car is in for service. I also noticed that the black plastic trim piece that goes around the console is loose in its chrome surround. On both the driver and passenger side, it is loose in the middle area and does not stay flush. Either a lack of adhesive or inadequate crimp on the surround piece. Again, very minor and it'll wait for later service.
Over 1,000 miles and that's the complete list. Much better build than my first C300, but still some minor quality lapses. I won't complain too much, since my Porsche also had some issues with the plastic trim pieces right after I got it.
#413
How is the touchpad on your car, has it continues to function?
I have a W205 C200 for 2 months since mid Jan 2015 without problem. However on the third, the touchpad seized to response. The click sensitive area no longer have the click feel. It does not function for 2 weeks and out of the blue, it started to function normal for a day and now it is back to no response again. Would appreciate if anybody can advice.
#414
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
#415
W205 C250 BlueTEC Avantgarde
W205 C250 BlueTec - early problems
I have just taken delivery of my W205 C250 BlueTec and the early problems I have experienced are:
- When the car is at running temperature, there is a distinctive lag (flat) when pulling off from a stop. It feels like a lack of communication between the accelerator pedal and the engine. MB advise that this is a software problem and a simple upgrade will sort it.
- The ADDBLUE pump at the back (underneath) makes a loud ticking noise for about 10 seconds after the engine is turned off. MB advise that this is normal !!
#416
#417
Have you changed it ?
#418
Polar White C200 A Exclusive Premium Business
A week ago the yellow engine light came on in evening. So I called the M-B 24 hour help. The technician called me and said that he will be in the repair shop in half an hour. So I drove to the repair shop and the technician connected the car to the computer. The problem was a faulty NOX sensor. In an hour we got the new NOX sensor and changed it. Everything is working again. I got home about midnight. I was pleased with this kind of service. I have driven with my car now 12000 km.
#419
Poor service and numerous problems
I have had my C220 two months, and it has been plagued with problems.
I initially reported the brakes pulling to the left, and with brake assist, the L/H front wheel locks.
I have also ad issues with the rear suspension banging and being very unsettled over bums and in corners.
Took two weeks before I could get a small 3 hour appointment.
After testing they determined there were problems and ordered new brakes and rear shocks. These were ordered and took two weeks to arrive. I had to phone three times before I was told the parts had arrived 5 days before.
They then told me the earliest appointment I could have was 15th June. After complaining, they manage an appointment in one week.
Since then, I have developed problems withe the GPS jamming, and a transmission glitch.
My colleague, who picked his identical car is also having the same issues and is also being give the run around by Merc.
Not impressed, and working on returning the cars and going to BMW.
#420
2021 E450, 2020 C43, 2015 C300, 2007 C280
Sorry to hear about your troubles, Paul Wilkins. Reports like these bring down the reputation of Mercedes in general and damage all owners, even those who have little or no troubles of their own.
Readers can't form any judgment at all about patterns of bad dealer service without some information about your location. Please add at least your country to your profile and, if in the U.S., your state. Of course, the more specific your location, the better, such as "eastern part," "Bay area," etc. If your want to name your dealer, fine. Others have done it.
#421
C250 BT sudden acceleration failure after pull off
Less that 700km on the clock in my days old C250 BT which suddenly 'developed' about a 7 second delay from depressing the accelerator to actually accelerating. Got caught in 3 intersections with this scary phenomenon so returned home. Called merc assist....said it's severe turbo lag. A pungent burning smell present. Can't accept merc assist's explanation. Will book car in at service station as merc assist can't 'assist' is this common problem...what's the cause? ?
#422
I have a C
220
You year manufacture 2014 first of all I like the car I have had plenty of Audi and BMWs and this is my first Mercedes
This is the first car ever had it seems to make it difficult for the owner to get into the vehicle the keyless entry doesn't work regularly and if that doesn't work then the remote doesn't work so you have to stand there for criminal having to get into your own vehicle.
And to top it all you take it back to Mercedes and they don't tell you you're the only one having a problem but then when you go onto the forums you can see that other people are having a problem
And just to let you know Mercedes iPhone does affect keyless and also the remote you better off keeping separate pockets
All cars have problems a problem that doesn't allow you to access your vehicle or even drive I class as a serious problem you're after sales service is shocking comparing it to BMW and Audi I am so disappointed you make out your brand is wonderful but from my experience it a nightmare
while at the dealership They rang me to inform me that While in their care a dent Has been put into the side of the car and they are graciously putting it right how
And by the way they seemed they can't find the problem the keyless entry on the remote control
That's not to that's nothing to do with the ad blue problem I've had this car has only done 13,000 miles and so far I have had to put in 30 L of add blue
The car tells you won't start if the ad blue runs out so I phoned Mercedes service they come out they tell me it will be all right it would just go into a limp mode or that isn't correct the car just stops leaving you stranded and just to point this out at blue is not easily available not every service station sells it so when a customer ring saying the cast telling him he needs to add blue will it be a good idea for them to bring it out with them
But I do actually like the car that it seems that the service side of things and the reliability is not where it should be
220
#423
Hey all, I hope this is the right place to post this even though I have a 2015 C63P Edition 1 (still W205 right?)...
After one day of ownership: in 95F (35c) degree weather the car refused to unlock. I tried the door handle and nothing happens (on either side), then tried the key FOB to unlock and same problem. I am leaning towards the key FOB acting up vs the car itself. I pressed the buttons to lock/unlock multiple times and the car did nothing at all.
I started to pop off the "manual key" cap on the drivers side door handle and after a few failed attempts it unlocked itself after I accidentally touched the door handle... really weird an embarrassing because I was demonstrating the car to friends.
Now... on to my BIGGEST PROBLEM.... the panorama roof sun-shield ate itself for breakfast. I literally used it 4 times in two days after getting the car and now it refuses to close and does this:
https://www.dropbox.com/s/n3kzw8jvz7...45.48.mp4?dl=0
I am very angry about the sun-shield and I pray the service center will do a good job repairing it without creating new problems for me.... this is my first MB and I'm a bit angry.
But otherwise.... I love the car.
#424
not the only one than not able to get in to car
#425
The only problem I've seen or heard of involving the sunroof shade has been loose fit and sagging when closed. Your problem with it being jammed like that is a new one.
