Ground to fender height
Couldnt reply to your PM as the text was too long.
FIN 55S 205048 1U 047165 VIN 55SWF4JB0FU047165
VeDoc Status Utlevererad
Användar-
ID d5jkumpu Datum 17.02.2015 - 18:51 Sida 1 av 3
Fordonsdata
Chassinummer (FIN) 55S 205048 1U 047165 X Märke Mercedes-Benz
Utrustningskoder
Lackierung 1 775 U
IRIDIUM-SILVER,
METALLIC PAINT
Invändig utrustning 141 A
LEATHERETTE - BLACK /
ANTHRACITE
Lackierung 2 Extrainfo invändig 140 A LEATHERETTE
Land 1 705
VEREINIGTE STAATEN
(USA)
Land 2 7XX
NORD- UND
SUEDAMERIKA
Extrautrustningskoder
Kod Beteckning
03A OEL-OFFSETMENGE +300ML OEL
055 AEJ 14/2
12B OWNERS MANUAL A.SERVICE RECORD-ENGLISH FOR USA/CAN
182 CONVERTER WITH DEV. CHARACTERISTIC
184 PRODUCTION PLACE USA
218 REVERSING CAMERA
222 FAHRERSITZ RECHTS ELEKTRISCH VERSTELLBAR
232 CODE VORLAEUFIG UNGUELTIG
234 BLIND SPOT-ASSISTANT
246 ANALOG CLOCK
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
258 FORWARD COLLISION WARN.(FCW) W.ACTIVE BRAKE CONTR.
264 SCHALTKULISSE FUER GETRIEBE AUTOMATISCH
265 KENNZEICHEN ELEGANCE/SPORT/ESPRIT/CLASSIC - IN
270 GPS ANTENNA
274 TELEPHONE ANTENNA
275 MEMORY-PAKET (FAHRERSITZ, LENKSAEULE U. SPIEGEL)
287 THROUGH-LOADING FEATURE
294 KNEEBAG
299 PRESAFE
301 ASHTRAY PACKAGE
309 CUPHOLDER
30P STORAGE PACKAGE
342B LANGUAGE INSTRUMENT CLUSTER/ HU - AMERICAN
345 RAIN SENSOR
Användar-
ID d5jkumpu Datum 17.02.2015 - 18:51 Sida 2 av 3
348 EMERGENCY-/ASSISTANT SYSTEM
355 PREPARATION FOR NAVIGATION RETROFITTING
35A VGS D4-0, D3-MUSTER
3U2 HEADUNIT AMERICA
427 AUTOMATIC TRANSMISSION 7-SPEED
440 TEMPOMAT
461 INSTRUMENT MIT MEILENANZEIGE UND ENGLISCHEN BE-
475 REIFENDRUCKKONTROLLE (RDK)
485
494 USA-AUSFUEHRUNG
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
51U HEADLINER FABRIC BLACK
51V SPEED- + LOADINDEX 95H XL+97H XL
522 RADIO AUDIO 20 NTG5 POSSIBLE FOR NAVIGATE
536 SATELLITE RADIO "SIRIUS" COMPLETE SYSTEM
551 EINBRUCH- UND DIEBSTAHLWARNANLAGE (EDW)
580 AIR CONDITIONING
5P8 CONTROL CODE SALES
632 HEADLIGHT UNIT LED W. STATIC LIGHT SYSTEM RHT
636 WEGFALL - WARNDREIECK
668 VERPACKUNG FUER VERSANDFAHRZEUGE
6P5 CONTROL CODE SALES
736 TRIM ELEMENTS - WOOD ASH-TREE BLACK
763 RADIO REMOTE CONTROL WITH PANIC BUTTON
772 AMG-OPTIK-PAKET - FRONTSPOILER, SEITENSCHWELLER U.
782 CODE VORLAEUFIG UNGUELTIG
805 AEJ 14/1
810 SOUNDSYSTEM
818 SINGLE-PLAYER CD
873 SITZHEIZUNG FAHRERSITZ LINKS UND RECHTS
876 INTERIOR LIGHT ASSY.
887 SAFE-BOX ABSCHLIESSBAR
889 KEYLESS-GO
893 KEYLESS-START
916 FUEL TANK WITH INGREASED CAPACITY
919 AIRCON COOLING POWER PACKAGE
986 IDENTIFIKATIONSSCHILD (VIN-NR.)
989 IDENTIFICATION PLATE BELOW WINDSHIELD
A20 DIREKTSTART
Användar-
ID d5jkumpu Datum 17.02.2015 - 18:51 Sida 3 av 3
A21 SHIFT BY WIRE
A59 FE-WANDLERGEH. 13,5
A65 FE-WANDLER 13,5MM
A89 REIBUNGSREDUZIERT
A98 T-SCHALTPLATTE MIT VGS 4-0
B03 DIREKTSTART / ECO START-STOP-FUNKTION
B09 KAELTEMITTELVERDICHTER MIT MAGNETKUPPLUNG
B59 DRIVING EXPERIENCE SWITCH (INDIVIDUAL DRIVING PROG
F205 BAUREIHE 205
FW SEDAN
G994 GETRIEBECODE AUSFUEHRUNG 94
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
J7A DSM: STAR2 BESEITIGUNG I/O-FEHLER-STEUERCODE W 10
J81 RELEASE JUNE
K15 STEUERCODE FUER SERVICEINTERVALL 15000 KM
L L.H.D
M014 ENGINE INCREASED PERFORMANCE
M20 DISPLACEMENT 2.0 LITER
M274 R4-GASOLINE ENGINE M274
P29 AMG SPORT PACKAGE INTERIOR
P31 AMG SPORTPAKET EXTERIEUR
P49 SPIEGEL PAKET
R02 ALL SEASON TYRES
R66 TIRE WITH RUN-FLAT PROPERTIES
U10 FRONT-PASSENGER SEAT WITH WEIGHT DETECTION
U22 FANGTISCH FUER INTEGRIERTEN KINDERSITZ
U26 SCHONBEZUEGE "SPECIAL" (FAHRER- UND BEIFAHRERSITZ)
VL FRONT AXLE HALF SHAFT, LEFT
VR FRONT AXLE HALF SHAFT, RIGHT
amo
The car has 2K miles on it. And according to the data card, 485 (comfort running gear)
I looked up the data card here, using the VIN number : http://carinfo.kiev.ua/cars/vin/mercedes/vin_check
- top of the tire to fender - 30% better on 19" wheels than what you see on 18" setup
- top of the wheel to fender - close to the distance you see on the car equipped with sport suspension and 18" wheels.
questions are: are you ready to sacrifice some comfort ? are you ready to pay 200-3000$ to buy such a combo ?
in my case, choosing 485 suspension has been an assumed decision; I've discovered the situation before the car was built ( by my own reading ), so I could influence the situation. I've even seen and driven a car equipped with this suspension, same engine, etc and have been impressed by the ride quality.
the thing I wasn't able to foreseen was the impact the color will have on car's appearance: the test drive car was black while mine is iridium silver and the gap above the rear wheel appears to our eyes more pronounced on non-black colors
I looked up the data card on my car and it did say 485 instead 486 even though going down the build list it listed:
P29 AMG LINE INTERIOR/AMG SPORTS PACKAGE INTERIOR
P31 AMG LINE EXTERIOR/AMG SPORTS PACKAGE EXTERIOR
So they should have installed the 486 option. I'll be going to the dealer on Monday, they're not too far from work and ask them to verify this.
There's another thread for the RWD C300 Sport that's having the same issue with the swapped 485 and 486 options.
https://mbworld.org/forums/c-class-w...300-sport.html
With K-MAC the statement “Full Front and Rear Alignment” again means what it says (currently only Toe adjustment)
No ongoing visits to dealers or alignment shops or constantly changing tire brands.
Fixing it right the first time with “Camber” adjustment - to resolve costly premature tire wear, improve traction. “Caster” - to resolve steering pull, improve brake and steering response/directional control with better turn in. Also essential if altering height, fitting wide profile tires/wheels, load carrying or curb knock damage.
Alternative is “crash bolts” (front only) but these are inaccurate one position. Only allowing .3 of one degree (1/8 of an inch) offset. Labour intensive to remove and replace. While K-MAC patented system is precise/accurate front (and also) rear “single wrench” ongoing adjustment on car (accurately under load)!
Kits replace the highest wearing front bushes (4) and the rear (4). The unique 2 axis design also allows twice the load bearing area! Improving brake and steering response.
Amo
Does that mean based on the car's configuration/options that the 485 is the only option applicable for my car and it's not a mistake?
Hopefully, Vic can give his input.
477 TIRE PRESSURE LOSS WARNER
486 SPORTS SUSPENSION
772 AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
782 AMG-SPOKEN WEELS 18" MIXED TIRES
VEHICLES WITH 4-MATIC-/ALL WHEEL DRIVE
M274 R4-OTTOMOTOR M274
P14 AVANTGARDE PACKAGE INTERIOR
What is your VIN?
Your car has the Comfort Running Gear SA code 485, it is not possible to have both 485 and 486
That's not to say I am happy with the ride height because I definitely am not. I had already explored aftermarket springs but the Vogtlands (IMO) are too stiff. I'm hoping MB-USA or my dealer will do the right thing and put the proper suspension on the car. It's either that or get me out of the car and let me order one with Airmatic...that would make me very happy.
I'm not requesting anything special, just to get what I paid for.
