BEWARE: I broke the windscreen with the wipers when cleaning the car!
Old Nov 25, 2014 | 10:31 AM
Benz Werd's Avatar
'24 GLB250. Previously '23 GLB250 '17 GLS500 '14 C250 '13 ML500 '12 C250 '08 ML500 '07 E500 '03 A160
Yes you read it right. I'm a nimwit and we've already had the windscreen replaced on our new C250 because I broke it while washing the car.
But it wasn't totally my fault. Read on and I'll explain why ....
Not sure if you've noticed but when the wipers on the W205 are in parked (off) position they slide right down to the bottom of the windscreen and hide under the bonnet which prevents you from lifting them up, and leaving them up while you clean the windscreen. However, I discovered you can grab the wiper arms while everything is turned off (wiper switch on stalk in OFF position, and engine/ignition off too) and gently slide them back up the windscreen to a position where you're able to lift them up and leave them up unaided so you can clean the lower part of the windscreen properly. Little did I know the other half decides to start cleaning the interior of the car, and of course wants to listen to the awesome Burmester surround sound while inside so on goes the ignition and "snap, bang, crack" was all we heard. The wipers tried to return themselves to the parked position at the bottom of the windscreen tucked away under the bonnet, but on the way down they got caught on the edge of the bonnet, which flipped the wiper blade assembly upside down and the metal section struck the windscreen quite hard and a small chip and a crack about an inch long appeared, which grew very rapidly as soon as we drove the car, and all the way to the top after a very short time!
Certainly won't do that again. Fortunately no damage to the bonnet, or wipers, but we did require a new windscreen, and fortunately again our insurance covered the $1,800 cost!
Figured I should share this so nobody else makes the same silly mistake!
Old Nov 25, 2014 | 11:18 AM
coladin's Avatar
2014 C63 507, 2012 R350
Wow, tough luck, but I have to be honest...I laughedas I could just picture it in a sitcom sort of way, not at the obvious expense it has caused.
Thanks for the heads up!
Old Nov 25, 2014 | 12:15 PM
mikeyw's Avatar
S205
Wow, i'm quite surprised there was enough force to do damage.
Old Nov 25, 2014 | 12:57 PM
c4004matic's Avatar
17 E43; 21 GLS580
Holy Crikey mate! Burmester, is a dangerous thing. I bet the alertness sensor activates if you listen to smooth Jazz
Old Nov 25, 2014 | 03:17 PM
gfmohn's Avatar
2021 E450, 2020 C43, 2015 C300, 2007 C280
Wink Only an intermittent fault
Little did I know the other half decides to start cleaning the interior of the car, ...
[Cackle! I apologize in advance, but I can't resist!] Maybe the fault is in your "other half". I'm sure that you have considered that possibility from time to time. But the fact that your "other half" was cleaning your car when the present malfunction occurred shows that your "other half" has given good service in the past and is not what some owners call a "high maintenance" model. So the present malfunction is probably an intermittent fault.
Has your "other half" recently required expensive repairs? Even so, be advised that the expense of replacing an only occasionally malfunctioning "other half" is not likely to be cost effective. Swapping out your "other half" for the "other half" of another owner is certain to lead to even more trouble. This is true even if the swap is temporary and the previous owner assists you in the swap. This is because each "other half" adapts itself to the vehicle and owner in which it is installed. Newer "other half" models can indeed display an impressive ability to adjust to multiple new owners. However, the long-term adjustment to the present owner required of older models tends to make them self-repairing in ordinary use. So if you avoid heavy-duty use and stresses which exceed the design limits of your "other half", you will be rewarded with many miles of faithful service.
Old Nov 25, 2014 | 08:13 PM
utsenmo's Avatar
2015 C400 4Matic
I totally know what you are talking about!. at least glad that you didnt get hurt.
I was trying to read the manual for instructions about lifting the wiper blade so that i doesnt catch snow. but the last time i did that it auto retracts when i power the car on again. I did put them down before powering so nothing bad happened.
Does anyone have any smart way of lifting up the blades? following the manual is too tedious.
edit: according to the manual, I thnk i need to roll the stalk to solid dash, which is position 4, and press the power on and off repeatedly to catch the wiper standing up.
Am i understanding it wrong? or did i read the wrong section of manual/.
Old Nov 26, 2014 | 02:33 PM
cleankutazn's Avatar
GLB 2023
wow that sucks....Didn't know the wiper retracts under the hood. Is the w205 the only mercedes that does that?
Old Nov 26, 2014 | 02:41 PM
greasykid's Avatar
2015, ML250 BlueTEC
Wipers
NO
Old Mar 9, 2018 | 07:23 AM
nslac's Avatar
2019 C63s Coupe
I know this is a old tread but the exact same thing happened to me today. Now I am up for a new windscreen
Going to ring up the insurance company tomorrow.
