i also use the S-class airbag like you. i had from the beginning sometimes a sound like "dong" when i turn the wheel slowly to left and then to right (when the car is still standing).
Now we have found (after changeing a lot of things) the the sound comes from the s-class airbag that fit not 100% (only 99%). when the engine is not running and you trie to move only the airbag to left and rigt you can feel the sound "dong" ... do you have the same issue ? i think it only needs some tapes somewhere
greets from vienna
This is a known issue with any airbag unit, remove the bag and the back steel plate, then tape the edges using felt tape, also around the circular holes.
Thank you ... can you explain this with fotos ?
back steel plate ? (from the wheel or from the airbag ?
the edges from the wheel or airbag ?
which circilar holes ?
thx !!!!!
thx !!!!!
Do you have an internal MB issue number ????? its called "TIPs Number" i think
because the dealer here dont know about an issue with airbags like you discribe
greets from vienna
another question:
there where you marked the red circles are screws normally....so dismount the metal steel plate... an then tape the marked holes ? right ?
* Airbag from S-Class Coupé
* Steering wheel trim from AMG preformace steering wheel
* S-Class Coupé control pieces with circuit board from original to get amber lighting
