Is it possible that there are other factors in play like a moisture leak from somewhere else? Like through the sunroof or door sills that just happen to condensate that way on parts of the MB-Tex?
It has to be defective MB Tex. In this picture look has shiny/oily the defective MBTex is vs. the rear center armrest MBTex that is not defective. I do not think you would have such a clear line of distinction if something was just condensing onto the MBTex.
I found this on the net, this explains what's going on with the seat but the health issue with plasticizer is of major concerns:
Re: Graphics – Vinyl Finish Alert - Mottling Notice a slight haze or mottling on your newly installed graphics? Here’s some information as to why this is happening.
Short Course on Vinyl Vinyl is composed of two simple building blocks: chlorine, based on common salt, and ethylene, from crude oil. The resulting compound, ethylene dichloride, is converted at very high temperatures to vinyl chloride monomer (VCM) gas. Through the chemical reaction known as polymerization, VCM becomes a chemically stable powder, polyvinyl chloride (PVC) resin.
PVC (PolyVinyl Chloride) resin is the key ingredient in vinyl. However, by itself, it’s a very hard and brittle plastic material. Additives such as plasticizers, stabilizers, lubricants, pigments and processing aids change the PVC’s physical properties and make it flexible.
Plasticizer Migration Vinyl resin must be blended with a plasticizer (such as a phthalate ester or phosphoric acid) to become pliable. The more plasticizers used in making the vinyl product the more flexible the vinyl becomes. These plasticizers make the vinyl pliable by sliding between the PVC molecules. Because the plasticizers are not chemically bound to the PVC molecules they can move from within the vinyl to the surface. This movement is called migration. When plasticizers migrate to the surface of the material it can cause surface distortion, like mottling (a spotty or hazy appearance on the vinyl surface), and can cause some inks or adhesives not to bond well. When plasticizers migrate to the underside of the material it can cause interference with the adhesive properties and degrade functionality of the adhesive of a pressure-sensitive vinyl.
This is a fascinating picture. The armrest is clearly from a different batch of MBTex. (presume you have inspected carefully & that some idiot has not installed a leather armrest in an MBTex seat?)
Stitching on those headrests could be better.
Unrelated...just wondering what the grey plastic thing is to the right of the armrest in the picture
I dunno...thought it was a booster seat, but it looks like it's coming through the triangular leather section beside the armrest?
it is a kids booster seat. Take a look at the seating area to the right of the gray and white armrest. Different material and higher than the other side.
The material on the rear center arm rest sure looks and feels exactly like the material on the seats. So either it's MB Tex from another source or they've done a heck of a job making MB Tex almost indistinguishable from leather (and accidentally installed leather). The MB Tex on the front arm rest, dash, and doors also appears unaffected.
I don't believe anyone has seen this on anything but the seats and the headrests. Even the TSB refers to seat covers and headrests only.
I created this account just to share my pictures, I have to say that I'm pretty annoyed by this.
I have an appointment with my dealer this Saturday. The service manager said that apparently it can be fixed while I wait, but I'll be sure to bring a copy of the TSB to ensure they actually replace the headrest and cover and don't just run a damp rag over the seats and say it's fixed.
The rear seats aren't as bad as the front, but still show signs of the "bleeding".
I picked up this car on November 8th, so I've only had it for 2 months. Less than 1300 miles on it and this will be the second trip to service (first visit was unrelated navigation / COMAND issue).
Funnily enough, my previous car was a Range Rover Evoque, and even though JLR has a reputation for poor reliability (isn't the joke that you buy two so you have something to drive while the first is in the shop?), the Evoque was solid (and real leather!). I was considering the XF 3.0 AWD, but eventually went with the W205 because I liked the newness. Maybe I made a mistake.
I wonder how they plan to solve the problems with the right seat covers as it couldnt be replaced at this moment according to the Service Bulletin.
My guess is the problem has to do with the passenger weight airbag mechanism and it's possible that has to be replaced/calibrated using something an average shop doesn't have?
The supplier has to develop a plan to add or divert volume of clean material or seat sets (likely just the covers, although the airbag occupant sensing calibration for the front right seat is a challenge) while not starving the Vance plant. This likely means a two-phase solution. Interim is cleaning seat while long-term will eventually be replacement, I would think.
Don't feel any guilt about the Evoque trade-in, great vehicle but in my opinion, not even close to the engineering you get from the W205. And not very attractive - that dramatic concept car design is getting very old, very quickly. I never for the life of me understood that model to be honest and it never deserved the Range Rover moniker.
I've been a long time Land Rover owner, grew up around them and know them well, but since 2010, their vehicles have been absolutely rock solid when it comes to reliability. Almost uncanny. Back in the day, they were very unreliable. Ever hear that saying that Land Rovers are the most unreliable, reliable car on the planet? Meaning, they may have broke down or presented insanely frustrating electrical issues, but when it came to off-roading ability, they are the best in the world. At least for all of their models except the LR2 and Evoque which are merely magazine cars.
As for the W205, this seat bleeding issue is pretty bad. Mercedes-Benz will fix this issue. BUT, I personally think they should try and mitigate it more quickly, since the side-effect is truly vomitus.
Is it reasonable to insist on a loaner until this is fixed, even if it takes weeks / two months? Even if there is no health issue, it's really gross sitting in oil / chemicals each time I drive my car. Even if I clean it all off, given the cold temps it all comes back the next time I drive it. I would hope MB would agree that having me sit in this oil on a daily basis for a month or two is not acceptable given the car is two weeks old.
Is it reasonable to insist on a loaner until this is fixed, even if it takes weeks / two months? Even if there is no health issue, it's really gross sitting in oil / chemicals each time I drive my car. Even if I clean it all off, given the cold temps it all comes back the next time I drive it. I would hope MB would agree that having me sit in this oil on a daily basis for a month or two is not acceptable.
I'm literally the nicest car owner you'll ever meet. When I go in with issues I'm nice as pie. And if I have to return multiple times for the same issue, I'm pleasant and patient. I'm very, very reasonable and understand cars have issues.
But if this issue, if it were happening to my car, regardless of brand, I would be requesting a loaner ASAP without question - as this is 100% no questions asked UNACCETPABLE!!!
Actually the dramatic design is what attracted me (and the mrs.) to the Evoque, especially since we got it right when they were first available. Definitely received a lot of compliments, even though it was the baby RR and not a "real" one (one day, I'll own a Sport!). Of course, the swooping design made the Evoque very impractical, that design was always about looks vs. function.
The technology in the W205 is amazing, especially when you compare it to the XF (to be fair it's probably the last MY of the current design). That's part of the reason I was so attracted to the C300. Although I do miss the Meridian sound system as I personally think it blows the Burmester out of the water.
Sorry about going so off topic
I'll report back after my service appointment on Saturday.
My wife drives a XF...when I drive it, I wear that sedan like a Tom Ford suit cut for James Bond.
