Burmester Equalizer Settings
Everyone's hearing is different, the quality of the source material varies, and people listen to a variety of music genres.
The only thing I would suggest is that you make sure the auto volume control stays off, since that has a negative effect on sound quality. The Surround provides a fuller sound, but it does change the clarity somewhat.
Whatever settings you decide on, they will be stored for each input ... so set them up separately. Play around with the equalizer until you find a pleasing setting for each discrete input.
1) Turned on Surround Sound. All seats. It truly enhances the result.
2) Turn off Automatic Volume Adjustment
3) Turn off HD. To my taste, HD saps some life out of the music.
4) Balance +1, Fader 0 We are after all, a lot closer to the left speaker.
5) Radio 3, 2, -2
6) Sirius 2, 2, 2
7) Media Register 2, 2, 1
I appreciate the ability to have different presets for the different sources.
I do, however, prefer my fader to be at -5, or biased toward the back seats - but again, this is just a personal preference. I change it back every now and then just to confirm that's what I like, and I always end up switching it back to -5.
Cheers.
Cheers.
I'm with you on the fader setting, and based on (perplexed) reactions from passengers who noticed my setting it is indeed quite personal. I put mine at either -4 or -5.
When my wife first heard a symphony played from Sirius XM in my new C300, she exclaimed, "That's unbelievable!" She has never been impressed by my home system. Her failure to be impressed by an audio system is not unusual; she is a professional musician. (I'll explain this below.) So when my wife was astonished by the realism of a large orchesteral piece, I was truly gratified.
BBC Music Magazine used to have a back-of-the-magazine feature on the audio systems of famous musicians, especially composers and conductors. Few of their systems were high-end or even very interesting. They were mostly systems they had bought when they first achieved enough professional success to buy good (not great) systems. They hadn't bothered to change anything since.
The magazine had to give up this feature. Not only were the musicians' systems not very interesting, the magazine explained that professional musicians are not much interested in recorded music. They don't listen to it for pleasure. (My wife does not either.) It simply doesn't sound like music to them. When they do listen to it, it is to see how musical competitors perform works in their own repertoire (tempo, dynamics, orchestral balance).
(The failure of my home system to exceed a really good auto system is not a black mark. I have some experience with custom car sound. After several years of work, my last pre-Mercedes car wound up with an audio system worth more than the car was at that point. When high-end audio designers (whether OEM or custom) take advantage of the opportunities offered by the precisely defined auto sound environment, they can achieve results that owners of home systems must spend thousands (or tens of thousands) to obtain. As far as I know, in the area of OEM audio systems, only partnerships with high-end audio suppliers like Meridian Audio (Ferrari, McLaren, Land Rover, and Jaguar), Mark Levinson Audio Systems (Lexus), and Burmester (Mercedes, Porsche, and Bugatti) have yielded results that have equaled better home systems.)
I actually have +3 on everything because it reduces the subwoofer droning at very low volumes. I'd like to add more bass but the subwoofer doesn't sound great on some songs.
Different sources have different needs. Even within the same source recordings will vary too.
i don't think there is any wholly satisfying default setting since the system has very little "coloring" to begin with. If anything I would leave it "flat"
