View Poll Results: Have you has Keyless Go failures?
Cold climate and, yes, I have had Keyless Go failures.
33.33%
Cold climate and, no, I have not had Keyless Go failures.
36.36%
Warm climate and, yes, I have had Keyless Go failures.
0
0%
Warm climate and, no, I have not had Keyless Go failures.
30.30%
Voters: 33. You may not vote on this poll
Are Keyless Go issues weather related?
Old Feb 20, 2015 | 04:52 PM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Forum member "emmotto" brought up an interesting possibility concerning the many reported cases of Keyless Go not working reliably.
The problem with Keyless Go, a problem which many of us have experienced first hand, is that it doesn't always work. It may work fine most of the time, but every once in a while either the door locks or the ignition simply will not recognize the fob. No big issue for the ignition since you can just insert the key, but a major problem if you can't get into your car. Weak batteries are not the cause of this, and there is no known software/firmware update that anyone knows of.
"enmotto" has suggested that this problem, which is very intermittent, can be caused by cold weather. He has seen this issue on other MB products, and has always noted the worst problems came during the winter months, and disappeared when warmer weather came around.
This purpose of this poll is simply to establish if this is a valid theory, or just an observation based on coincidence. Let's find out.
OOPS ... have you HAD, not have you HAS, failures. Darn fingers! Who put that S right next to the D?
Old Feb 21, 2015 | 08:04 AM
StanNH's Avatar
Not much of a response so far, but still not one failure reported from a warm climate.
Another idea ... has anyone tried unlocking the car with the MBrace app when the car failed to recognize the fob?
Old Feb 21, 2015 | 09:27 AM
richardamp's Avatar
2015 C 300
I live in cold weather and it has worked flawlessly for me. In fact, I was really impressed with how well the system works. With my Lexus I had to push a button on the door handle, but with the MB it just takes a quick touch almost anywhere on the front of the handle.
For those having issues, is it the same issue with both of your fobs?
Old Feb 21, 2015 | 09:53 AM
StanNH's Avatar
I had no issues with Keyless Go until a few weeks ago. Excellent system, but quite a few of us are seeing intermittent failures. I'm convinced the problem lies with the receiver in the car itself rather than the key fobs.
Old Feb 21, 2015 | 10:29 AM
Jinzen's Avatar
2015 C300 Luxury
Never had any problems with keyless go yet.
Old Feb 22, 2015 | 03:03 AM
SofFMike's Avatar
2015 C220
I don't have keyless go but I have been locked out several times with the regular fob(s). This has happened in the summer and winter so temp doesn't seem to be an issue.
The system resets after about a couple of minutes or if I walk away and come back.
Old Feb 22, 2015 | 09:59 AM
StanNH's Avatar
I hadn't even considered that this problem might affect the regular fobs as well. Your problem has me convinced that the root cause is an intermittent receiver in the car itself.
Old Feb 22, 2015 | 10:08 AM
SofFMike's Avatar
2015 C220
Stan, I tend to agree but what really makes me wonder is I had the same system in my last car, E250 Cabrio, with no issues at all.
In the end it's aggravating but the issue rectifies itself in a minute or 2 and is intermittent. I have more important things to worry about so no sleep is lost over this.
Old Feb 23, 2015 | 08:56 AM
goherdibg's Avatar
2023 EQS 580 SUV
Unfortunately we may not be able to determine if it is temp related until May or June....
Old Feb 23, 2015 | 03:30 PM
emmotto's Avatar
2015 BMW 335xi M Sport
Let me be clear - I never had a KG error that kept me from entering or starting the car in a non-KG fashion - ie; if KG failed to work by pulling on the door handle or by not starting when I pushed the start button - then it WOULD work by unlocking the doors by pressing the unlock button on the key.
In every instance except two, when I pressed the unlock button on the key, the system would return to normal operation. The 2 exceptions to this were when it decided it could no longer find the key while I was driving! Then it didn't matter how many times I pressed the unlock button - nothing happened until I stopped the car and turned it off and then back on. See photo of me driving 65mph when this happened... yes, that's the key... in the photo...
This was in my 2012 C300 but I had a similar KG problem the very first day I had my 2015 C300...
But spring is only a few months away...
Old Mar 4, 2015 | 06:35 PM
sure**shot's Avatar
2015 S550, 2013 SL550, 2015 ML250
Keyless go problems and cold weather
I have had 8 keyless go MB vehicles, since my 2003 SL 55 (wallet key), and invariably, cold weather or not, when the key was not recognized, a battery change corrected the problem. BUT my 2015 ML250, did not recognize key- so pushing the open icon on the key allowed recognition and a keyless start. Battery voltage was 2.95. New battery, no problems. WE NEVER OPEN AND CLOSE OUR CARS WITH THE KEY OR START THEM WITHOUT KEYLESS. This car was delivered 3 1/2 months ago! (OK bad Panasonic Battery).
But what's really frustrating is the 2015 S 550 delivered January 29. One out of five times, the key was not recognized by the ignition! I was only locked out once from touch handle, but pushing open on the key, solved that problem. One key had 2.97V, the other 3.01V. New batteries, no difference. Software upgrade was done and keyless start worked flawlessly for two weeks, even though the lead mechanic at the dealership did not think it would make a difference. This morning it was about 15 degrees in the garage and the key was not recognized by the S550 ignition until the open car button was pressed. Battery - 3.03Volts.
But my 2013 SL550, mostly idle winters because it can't get up a slippery driveway with the Bridgestone summer tires-has never a keyless problem weather not withstanding and it has same batteries as when delivered. (I like to drive it winters if my driveway id free of ice and snow and the roads clean.) IT IS VERY COLD IN MINNEAPOLIS, and I think keyless problems are to some extent weather related, but the keyless problems seem to be worse with 2015 model year vehicles. I suspect they have changed something, and its for the worse.
Old Feb 26, 2017 | 01:30 AM
Humood's Avatar
Mercedes s550 2013
the Mercedes key is damage two of my mobile phone. I don't know why? but am sure from the key, the mobile phone screen damage. the keyless go key "Mercedes key" is very bad sign key.
Old Feb 26, 2017 | 03:44 AM
kleinebin's Avatar
W214 AMG Line
I've had 'Key not detected' once whole sitting in the car with the key in the cup holder.
I exited the vehicle, locked and unlocked the car three times (this used to reset the W204, have no idea if it does on the W205) and it stopped the error.
Old Feb 26, 2017 | 07:46 AM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Sounds like operator error. Put your keys in a different pocket .
How are you sure it's the car key? Do you have a house key on the same key ring?
Old Feb 26, 2017 | 12:59 PM
GerritKw's Avatar
C350e
To save batteries you can disable the keyless function by clicking the lock key twice.
I sometimes notice that when i lock the car with the fob i use the double click action accidentally because on my old car this put the car in a safe lock mode.
Then next time i want to enter the car it doesn't respond. So next time yours is not working, think if its the system or the user causing this issue.
Old Feb 26, 2017 | 03:18 PM
Tej7's Avatar
C43 Coupe
The only issue I ever experience is when I try to open the trunk by kicking under the rear of the car (I have a coupe).
Old Feb 26, 2017 | 03:35 PM
StanNH's Avatar
Since this thread is alive again, I'll add some updated comments.
My first, early build, C300 had many Keyless Go failures, and I was locked out of the car several times. When that happened, I had to wait a few minutes, and it would somehow reset itself and work normally again. Pressing the unlock or lock fob buttons did nothing.
My replacement C300 has been much better, but I have had some failures. The dealer did find an error code, and applied an update. It still does it once in a while, usually a failure to lock when the door handles are touched, but a simple press of the lock or unlock button now seems to provide a quick fix. I have also had some fob not detected errors and used the fob in the ignition. If that happens, after starting the car with the fob manually, I can shut the car off and the fob will always be recognized and the car will start normally again.
It seems the more dependent on computers these cars become, the more computer-like glitches we have to deal with.
Old Feb 26, 2017 | 03:59 PM
kleinebin's Avatar
W214 AMG Line
I had the same issue. It would not work as advertised.
The dealer fixed it and now it's flawless.
Old Feb 26, 2017 | 06:12 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
No issues
Old Feb 26, 2017 | 10:58 PM
Tej7's Avatar
C43 Coupe
Mine works about 90% of the time. I'll have to pay closer attention to the weather next time it decides not to cooperate lol.
Old Feb 27, 2017 | 12:38 PM
KAMCAD's Avatar
2018 C300 Sport 4matic
I've noticed lately it is harder to lock when it is cold in the morning. It was 28 F the other day and touching the door handle didn't work. My battery is 6 months old. Also 3 times in the last year the car would say no key. Like others have said manually locking/unlocking with the fob worked and the car would start.
