Music Register Upgrade
Does anyone know if there is a way to upgrade the music register capacity? 10GB is just too small. I'd like to have at least 20GB, or even more. Hard drives are so cheap I don't know why MB would only include a 10GB drive. A 256 GB solid state drive is about $100. I wonder if it's as easy as changing out the hard drive in a PC. I know I could use an SD card or USB drive, but I think a larger capacity music register hard drive would be more convenient.
I have an SD also but would like to have a larger capacity music register hard drive. Cheaper isn't an issue. If it can be done, I'd ask the MB dealer to do it. I sure most owners would like a larger music register. There may be some technical reason the register is limited to 10GB. Even the S-Class only has a 10GB music register.
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
If its like BMW, its a partition, meaning removing it leaves no multimedia systems running and you'd need to clone the existing data sector by sector into a new hard disk and hope the system will recognise it. To be fair if you're IT savvy its not difficult. Its probably more difficult taking the dashboard apart to get to the HD.
1 Post
MB W204, VW Polo, Audi R8 V10 - SOLD.
On the W204 forums I think there are some threads that have expanded the music register.
Also there is a video or two on youtube showing how you can get to the internals behind the CD/DVD player.
Personally I would just use a USB key which is what I have done in all of my cars that allow it. I wouldn't want to risk bricking the system!
1 Post
http://store.westerndigital.com/stor...FeHLtAodTkkAww
That way I can edit my music without taking the HDD out of the car if I have it hooked up to my home WiFi.
Question: Does the USB port switch off when the car is shut down and locked? I don't want to risk draining the car battery if I don't drive it for a long time and this HDD plugged in. Does anyone know?
I would highly discourage the use of a conventional hard drive for this purpose. The main reason is temperature... conventional hard drives have high speed moving parts that weren't designed to be used in the crazy temperatures the inside of a car sees (cold or hot).
I would stick with flash memory, found in USB thumb drives, SD cards, and SSD hard disks.
C200 AMG Line Premium Plus
I normally use a 32/64 GB USB key but I was thinking about using something like this:
That would limit its usefulness in your car.
1 Post
An alternative option is to get a solid state USB stick with networking capabilities which will not have this problem and also will address subsequent issues highlighted in further posts. I found this:
http://www.pcworld.co.uk/gbuk/data-s...pid=display~RR
http://www.pcworld.co.uk/gbuk/data-s...ml#srcid=11026
That could do the same job. The second has an SD cards so you can expand the memory...
Only thinking out loud at the moment. I haven't got the car yet!
I don't have the drive. It was only a thought about what I could do to wirelessly access the music from the home wifi and update easily. I had a quick look online and it looks like it will charge off the USB and a mains charger is supplied if you want to charge it through the mains. Whether it will be able to draw enough power from the car's USB is a separate issue though. I suspect this shouldn't be a problem as the standard USB is able to power a normal HDD and charge a phone...
Like you, I'd be interested in being able to update my in car music remotely (when it was in the drive) without removing the media device.
Must take a trip to PC World for a look.
1 Post
Obviously buying online will be cheaper still and there there may be other options. I know there are also wireless SD cards - eyeFi is an example.
I'm not sure of whether you can write to the drives over wifi - I hope so. I haven't done much research to be honest...
