Squeaking noise after lowering with H&R
Old Dec 14, 2016 | 11:55 PM
jatt143's Avatar
2018 C63s AMG
Hey guy's I got the exact same squeaking noise as described above which parts need to be greased or sprayed? I'm on 1.2" drop with H&R Springs
any pics will be helpful.
Old Dec 15, 2016 | 10:29 AM
BF3PDZ's Avatar
E class, C class
Mine is squeaking too, but on the standard AMG line suspension.
Old Dec 16, 2016 | 11:52 PM
exdes's Avatar
2015 C300 4matic
http://www.benzworld.org/forums/w245...ion-fixed.html
it's for B class but you'll get the idea what to look for.
Old Dec 28, 2016 | 11:29 AM
W205C43AMGCoupe's Avatar
2017 AMG c43 coupe
Originally Posted by IstvanC
I was with them the whole time, I have myself probalby changed springs / shocks / coilovers on over 10 of my cars. So everything was done as it should and it is a very simple job.
We have now tried loosen the bolts to some bushings and etc when the car is on a lift with the wheels in normal mode, maybe it could be that there is a pressure in the bushings when everything is working in another angle. But that wasn't the problem either. The shop came to a conclusion that its probably the springs squeaking up against the rubber seat on top.
I have been in contact with H&R, and they are telling me I have to buy a tube that we put on the springs. But not enough that I have to pay extra for the tubes, we have to take appart everything again at a shop, and do another wheel alignment. I'm kinda pissed over this. They should warn you when you buy that this could occur. Then I would have bought it straight away. Its not the money for the tubes, but the whole job off doing everything over again.
I'm about to install the H&R Sport springs on my c43 coupe. What are the tubes you need to buy? Do you have a part #, picture, or know what they are called?
Thank you!
Old Dec 28, 2016 | 06:51 PM
jatt143's Avatar
2018 C63s AMG
Thank you!
don't do H&R mate .. ride is **** on them. go with KW. that's what I'm going to buy
Old Mar 21, 2018 | 04:49 PM
munis's Avatar
2021 Mercedes C63s AMG Coupe
I have this problem as well. Can anyone please provide a picture of this bump stop? Cause the one in the links are not working.
Old Apr 3, 2018 | 08:13 AM
  #32
munis's Avatar
Anyone?
