2015 C300 Light upgrade
Old Apr 28, 2015 | 05:47 PM
aceachuth's Avatar
2015 Mercedes C300
I currently own a 2015 C300 with the regular halogen lights.
I really wanted to upgrade the headlights to Xeon Headlights with HID (which imho looks way more nicer). I checked with the dealership, they said they cannot do it (without providing me a reason as to why they won't).
Can the headlights be upgraded? or is it a limitation in the car that u cannot upgrade headlights (coz *i don't know* the Xeon lights may need more power or something?).
Also, upgrading the headlights should not affect the warranty right?
Any response is highly appreciated.
Old Apr 28, 2015 | 06:15 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
HID requires a new system because the power requirements are different and needs a balast to manage the power requirement. Regular bulbs are like a candle compared to HID which is like a laser pointer.
You may find a kit for HID's but you'd have to buy entire new headlights and get them installed and wired, easily over $1000 for the change to HID.
Xenon by comparison is also a bulb like Halogen but the gasses are different. Xenon lasts longer, looks more whiter and is just a bit brighter with the same wattage, but it costs more, and it's still a bulb compared to HID which uses lenses to focus light created by an electric arc in a vacuum of metal vapor in a capsule.
There are HID kits for universal systems but would require modification to your headlights including cutting and such (depending on the kit), which could void your warranty.
-RyanG
Old Apr 29, 2015 | 11:22 AM
aceachuth's Avatar
2015 Mercedes C300
Thanks RyanG for the information. The above information was highly useful.
Its unfortunate that Mercedes doesn't allow you to upgrade the lights.
But to your point about the Xenon Headlights (without the HID), I can still get those correct without voiding the warranty (since its the same wattage and all).
Old Apr 29, 2015 | 11:26 AM
bartola's Avatar
CLA-250, C-300
Search the board. There is a guy in here that did a conversion, if you really like the look and are savvy on handling electric components, you might be able to do the conversion DIY.
Old Apr 29, 2015 | 01:04 PM
Boudicca's Avatar
Mercedes C200 (W205) Avantgarde petrol RWD
This is the thread- this guy is persistent
https://mbworld.org/forums/c-class-w...ghlight=Huyuci
Old Apr 29, 2015 | 03:51 PM
hpilot's Avatar
2015 C300, 2025 GLC300 4Matic
Yes, but they are totally worthless. The coating they put on the bulbs ruins your visibility in rain and fog. Read about it here
http://www.ebay.com/gds/Whats-the-Di...8258733/g.html
Old Apr 19, 2016 | 01:11 PM
autolight_mtius's Avatar
C180K 2009
Hello
greetings from Mauritius
It is difficult to upgrade your existing Halogen headlamp to Mercedes projector lens+ HID ones due to coding issues and headlamp harness differences.
What is easier to perform is a halogen to HID conversion, by using H7 HID bulbs made for reflector headlamps(bulbs are either for LHD or RHD) and Quick-start CANBUS ballasts rated at 35W.
IF you want more info you can send me a PM.
Old Apr 19, 2016 | 09:08 PM
Mr. J's Avatar
C450, GLC43
Originally Posted by autolight_mtius
Hello
This!
Question? Can momentary on functions and keyless entry headlight on functions be disabled with command? This would need to be done for most HID conversions.
Old Apr 20, 2016 | 01:32 AM
C180K 2009
Hello Mr J
Why would you want to disable these functions?
And as far as i know they are not accessible via COMAND.
Have a nice day
Old Apr 20, 2016 | 03:05 PM
Mr. J's Avatar
C450, GLC43
Hello Mr J
Have a nice day
Unless the tech has changed since I last played with it, momentary on functions will cause problems with HID systems very quickly. The momentary on function for headlamps either needs to be extended for a greater interval or turned off altogether in order to avoid damaging the HID system.
Has something changed recently that I'm not aware off? I think all the Morimoto retro kits still advise to disable the momentary on function for HID headlamps. Depending on the setup, sometimes the DRL need to be disabled unless that function can be routed to a LED emitter that also tricks the canbus.
Old Apr 20, 2016 | 03:45 PM
CO2010's Avatar
2015 C300 RWD Sport Premium
Personally I don't know why Mercedes even offered the C Class with the standard halogen lights. Why not offer roll up windows while your at it.
Old Apr 20, 2016 | 04:14 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Because that way they have something they can upcharge on packages. Most ridiculous they've done was offer folding rear seats as an upgrade option....
Old Apr 21, 2016 | 12:17 AM
C180K 2009
OP asked about a way to upgrade the halogen headlamp, which comes without Xenon and LED strip. That's why i suggested the upgrade to HID bulbs.
AFAIK the momentary-on will not affect the working of the HID ballast(lifetime maybe) as the quick-start ones go to maximum brightness in about 6-8 seconds. I have HID on my fog lamps in my W204 and i have been using them for about a year now with no problem.
Even here in Mauritius i don't understand why Xenon+ Led wasn't given in the basic packages. We're also busy doing retrofits for front and rear camera in those cars. Cheap moves from MB
Old Sep 20, 2017 | 04:19 PM
Mikevang08's Avatar
2016 mercedes c300
Hi I also made the mistakes that you did. I would like to ask you more information on it. Is there another way I can reach you to discuss more into this?
Old Sep 20, 2017 | 05:31 PM
DBOC205's Avatar
W205 C250BT
The momentary on is an issue with cheaper ballasts because with HID the ballast has to strike the arc which is a high voltage (burst) ignition sequence for the light to start working. Once the arc is stable the ballast adjusts voltage down as the light warms up. Basically, continual high discharge rates and cheap capacitors or components don't go well in the long run. It'll work for a while and then die. You can get quality digital ballasts which are suited for momentary on/off (e.g. those suited for high beams) but even there it's difficult to know unless you have reviews or recommendations.
Have a look at retro fit LED instead of HID kits. They use the same principle (i.e. replacement bulb which is suited to fit the socket of choice), but their electronics are completely different and much better suited to short on/off bursts. The LED kits can however cause you other issues - especially on CANbus systems which are designed to monitor the load of things like your lighting for example.
Old Sep 20, 2017 | 06:56 PM
AZN Optics's Avatar
In addition.... LEDs in housing not designed specifically to capture LED surface mounted light spread will result in reduced throw distance, dark spots, and light scatter. LEDs just don't have true 360 spread which your housing was designed to capture.
Old Sep 21, 2017 | 01:03 AM
Mr. J's Avatar
C450, GLC43
+1
I've retrofitted LEDs on other vehicles with reflector housings as fog lights. They will not work well for retrofitting the main headlamps in a reflector housing. The housing would need to be replaced with a projector style. I haven't seen any aftermarket LEDs yet that can compete with a good HID setup. The factory intelligent LEDs on my car are amazing but all the aftermarket LEDs I've seen are not even in the same league.
Old Sep 21, 2017 | 01:13 AM
DBOC205's Avatar
W205 C250BT
All true. The lights need to be projector based. Even if you're ignoring the illegality of doing so, using HID or LED on a basic reflector style light is not only a danger, but a bloody nuisance to other road users.
Old Sep 21, 2017 | 07:01 AM
C180K 2009
Led bulbs nowadays come with certifications such as DOT, Emark, Rohs and CE.
Cut-offs are similar to halogens, as bright as HIDs and glare-free.
If you'd like a pair we'd be glad to have them shipped to you. Shipping fee applies.
Old Feb 20, 2024 | 10:10 PM
Antoinebut361's Avatar
C300 Mercedes 2015
I installed halogen headlights in my c300. The only light comes on are the amber lights? Can anyone help or have an idea
