Tires are too BIG!
I am now waiting to put a set of 265/30/20 and 235/35/20. Les Schwab tells me they cant find a 275/25/20 Rear and 235/30/20 front?
I am now waiting to put a set of 265/30/20 and 235/35/20. Les Schwab tells me they cant find a 275/25/20 Rear and 235/30/20 front?your info doesnt help at all if any, you have a 20x10 with what offset ? I am pretty sure that 285/30/20 is doable but with the correct offset if not you will rub just like you are right now..
The overall diameter with the 19s Rear 255/35/19 is 26.2 and the 285/30/20 is 26.73 so no mayor difference on height
Stock rim specs 19x8.5 et 52 so a 20x10 with a 45-50 offset should work just fine
