Canadian C450 AMG Sport
Old 11-15-2015, 11:30 PM
  #51
racingmb's Avatar
2008 C230 (204)
I just had winter wheels installed on C450. It was hard to find one! Even the one with the same specification posted above from 1010tires are way too close to the nuckle. I ended up using +32mm offset instead and it works just fine. I'll post picture soon.
Old 11-16-2015, 06:31 PM
  #52
autopal's Avatar
2016 C450
Originally Posted by Mark Harrison
I bought my wheels from my local tire shop who got them through Canada Wheels....
Did you have any luck with your install?
Bad news guys, the wheels don't fit! 1010tires assured me that they would, but they are slightly touching the brakes. The good news is they will give me a full refund because of their fitment guarantee, the bad news is, I am back to square one, and with snow expected anytime soon, I will have to park my car.
Any solutions? HELP!
Old 11-16-2015, 06:46 PM
  #53
Mark Harrison's Avatar
2016 C450
Can you share the brand, model and supplier?
Old 11-16-2015, 07:04 PM
  #54
2016 C450
I will be mounting my winter rubber on the stock AMG wheels and expect I need to wait until Spring until there are more options. That is my first option but if there are some solutions that work, i will explore those.
I was advised by Vivid Racing that the HRE FF01 will fit the C450. I was also advised that Wheels Boutique can supply them for about $2500 USD plus shipping!
Old 11-16-2015, 07:25 PM
  #55
cil254's Avatar
C220
Anyone has TPMS on their Canadian C450? I got the 19" wheel option on mine and it comes with TPMS.
I'm debating if I should get separate wheels, winter tires and 4 sensors ($400 at MB dealer) or just get some 19" winter tires that will have to be mounted on existing rims.
What happpens without TPMS sensors, just a malfunction message or also the orange light on the dash?
Old 11-16-2015, 07:35 PM
  #56
2016 C450
My dealer checked the VIN and mine has TPMS. I bought the sensors from Benz.
My personal preference is separate wheels for the winter tires. Partly to save wear and tear on one set of wheels and partly because I like wheel options.
MB wheels are hard to buy at the moment. I was advised that the 5 spoke 18" is the only one available and about $4K for the set. I will slap my winter tires on my stock wheels this winter and see if I can find wheel options in the Spring. I had a set ordered by they did not fit. Others have had issues with fitment on non OEM wheels.
Old 11-16-2015, 08:26 PM
  #57
Takobo's Avatar
C400
Just want to share my setup from 1010tires. 18x8 et45 with 225/45/18 Blizzak WS80, TPMS not required (I have 19'' summer and airmatic).
Old 11-16-2015, 08:30 PM
  #58
autopal's Avatar
2016 C450
Please send me the exact name and offset for those wheels. I just tried a set of wheels I bought from 1010 tires, and they don't fit. Thanks bro
Old 11-16-2015, 08:31 PM
  #59
cil254's Avatar
C220
Thanks, what do you mean TPMS not required? Do you not get an error? Did your original rims come with TPMS? Mine do.
Old 11-16-2015, 08:44 PM
  #60
Takobo's Avatar
C400
I think you have ordered wrong offset. mine are ET45, and yours ET35. that could be the reason.
Old 11-16-2015, 08:47 PM
  #61
autopal's Avatar
2016 C450
Nope, mine offset is 45mm. I just realize your car is a C400. It's the bigger brakes on the C450 that is the problem. Those wheels are fine for the C400, they don't fit C450, I found out the hard way
  #62
Takobo's Avatar
C400
From my understanding, Canadian W205 use passive TPMS, which is using ABS sensor to detect. Therefore, I don't need TPMS sensor. After I installed my winter set, adjust the tire pressure, start the engine, restart the tire pressure monitor from on board computer. No error message, no warning light.
Old 11-16-2015, 08:49 PM
  #63
Takobo's Avatar
C400
I thought C450 and C400 are using the same brake. I don't see this difference on C450 spec sheet. Well, good luck finding correct wheel.
Old 11-16-2015, 09:15 PM
  #64
2016 C450
I thought the same too. Benz ran my VIN and said it has TPMS. Having the system show tire pressure for each wheel caused me to check.
My BMW had a passive system. The Merc, at least my C450, has the TPMS. Check with your parts department to be sure.
Old 11-16-2015, 09:16 PM
  #65
autopal's Avatar
2016 C450
C400 front brakes 13.5inch, rear 11.8inch, C450 front brakes 14.2inch, rear 12.6
Old 11-16-2015, 09:20 PM
  #66
2016 C450
The front and rear rotors are about a 1/2 larger on the C450 and the front calliper us huge. The front axle is the same as a C63. Not a lot of room when I had my wheel off.
Old 11-18-2015, 10:28 AM
  #67
cil254's Avatar
C220
That's correct most have passive TPMS, some, like mine have sensors in the wheels. You can also tell by looking at the valve stem. It's not a flexible rubber stem but a metal one with some sort of bolt on it.
I've decided to go with tires only, 19" winters on existing Rim.
Old 11-23-2015, 08:17 PM
  #68
Rinial's Avatar
2013 ML350 BT, 2016 C450
Just placed my order for a March delivery
Polar white
Cranberry leather
Premium
Ash wood
AMG steering wheel
19 inch wheels
Still undecided on the intelligent drive option. Have about a week to decide on this.
I'm starting to look at winter tire and wheel options.
Has anyone had any success with aftermarket 18 or 19 wheels?
If so can you post which wheels?
Old 11-26-2015, 09:48 AM
  #69
Mtl20v's Avatar
2013 E350 4M Wagon & 2013 C350 4M Sedan
delete
Old 11-26-2015, 07:57 PM
  #70
nvestr's Avatar
2016 C450 AMG
Originally Posted by Mtl20v
delete
By editing your post, does that mean that the Replika wheels you mentioned won't fit a C450?
Old 11-26-2015, 08:29 PM
  #71
First-e320's Avatar
2015 C450; 2008 RX400h
I am someone who always uses the cruise control and I found on a test drive that the intelligent drive option as a useful feature that extended the features of the cruise. The cruise will not only hold my speed but will also adapt to the traffic so I don't have to keep disengaging and engaging the cruise for the occasional traffic bunching.
Old 11-26-2015, 09:47 PM
  #72
Rinial's Avatar
Tirerack now shows no wheels available for the C450.
Old 12-14-2015, 02:20 PM
  #73
stolenfire's Avatar
None
Hey guys, quick question regarding the Power Trunk Package for C$675. What exactly does this package include? Thanks
-buttons in the trunk to power close/lock the car
-hands free trunk access?
Old 12-14-2015, 04:32 PM
  #74
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
Touch a button to close the trunk
Stick your foot under the rear bumper to open the trunk
For me, there are many better ways to spend $675. But that's just me, perhaps.
Old 12-14-2015, 05:26 PM
  #75
autopal's Avatar
2016 C450
I'm with you there, that's an option that I struggled to see the value, so i didn't get it. For me, I bought the C450 more for the sport, than the luxury, and every option that I wont use only add unnecessary weight to the car.
Quick Reply: Canadian C450 AMG Sport
