Key fob opens trunk from 75' away
I tested how close I needed to be to open the trunk and amazingly I could open it from 75 feet away.
There should be some sort of distance control as to how close you have to be to open the trunk.
So the hatch went back up.
Then the rain convinced it again, so the hatch went down.
And up.
And down.
And up.
etc...
Ended up walking the completely length of the carpark away from the car to get the key out of range and eventually the boot stopped dancing. I then moved a little closer into the fob range and pressed the fob button to lock the car rather than go up to it and use the keyless. Must now get round to turning off the comfort opening because heavy rain tends to happen a lot in the UK in winter!
