Maintenance on new 2015 C300
Old Sep 3, 2015 | 10:29 PM
livel1fe's Avatar
C300
Guys,
I got my new 2015 C300 almost 2 months ago. The car now has close to 1200 miles. So far, the only thing that I have done to the car is fill gas and wash it a couple of times.
Are there some other things I should be doing? Like checking tire pressure, oil levels etc?
Thanks for your time and advice.
-Sri
Old Sep 3, 2015 | 10:34 PM
darwin329's Avatar
w205 c400 c63s
you may want to wax and apply sealant to protect your car..You like modifying cars?
Old Sep 3, 2015 | 10:45 PM
livel1fe's Avatar
C300
Thanks for quick response. I am actually thinking of applying "Ultima Paint Guard Plus" or do some waxing with Meguiar's products.
No, I am not into modifying cars.
-Sri
Old Sep 3, 2015 | 10:48 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
Originally Posted by livel1fe
Guys,
-Sri
Other than keeping the car nice and clean and putting a nice coat of wax on it, there's really little you need to worry about. Check the tire pressure regularly and your car will tell when it's time for Service A (typically about the 1 year mark).
Old Sep 3, 2015 | 10:50 PM
livel1fe's Avatar
C300
I thought the car will indicate if the tire pressure is low. Should I still check every month or so?
Old Sep 3, 2015 | 11:04 PM
rbrylaw's Avatar
The TPM system will tell you if the tire pressure is low. But in my opinion that's not enough. Running on tires with less than optimal tire pressure reduces MPG and lessens the useful life of a tire. So yes, check tire pressure regularly.
Old Sep 3, 2015 | 11:16 PM
darwin329's Avatar
w205 c400 c63s
still check it regularly. to maximize fuel efficiency/economy and less wear on tires too... meguiars is a nice brand or you may want to try pinnacle wax. you can clay your car first then sealed it and wax ..
Old Sep 3, 2015 | 11:33 PM
jakc's Avatar
2016 C300
It's a Mercedes. The car will tell you if you have to check oil, tire pressure, or anything else. Just drive it
Old Sep 3, 2015 | 11:57 PM
PeteInGilroy's Avatar
'25 MB GLE 450, w/airmatic
Regarding tire pressure, I would check the pressure every 2 or 3 months. The other day, after owning my car for 6 months, the TPMS warning message came on along with the red tire indicator in the dash. Since this was the first time I saw that, I got a little nervous as I was about 30 miles from home. But the center display showed the current tire pressure in each tire, none was lower than 30, but enough to trigger the alarm.
When I got home, after the tires cooled, I put air in them and haven't seen the warning since. I also reset the system to use the current values to monitor the system.
Just saying, if you don't like to get warning while you are driving keep you tire pressure at the recommended pressure.
Old Sep 4, 2015 | 12:20 AM
jakc's Avatar
2016 C300
In my C63 during the winter months I get a warning at 35psi and drove through the entire season ignoring it as it goes back up to 40psi after the tires warm up in 15 minutes or so. There are not many (if any) issues driving on under or over inflated tires for an extended time other than excess tire wear on the outside edges for under inflated and center of tire for over inflated. As long as you're not carrying 5 people and a piano mounted on your roof or speeding around a track you'll be fine.
Old Sep 4, 2015 | 12:24 AM
I agree with all of that, but I had been driving for 30 minutes when the warning light came on. Plus if you don't air the tires, you will get the warning message every time you start the car.
Old Sep 4, 2015 | 12:30 AM
darwin329's Avatar
w205 c400 c63s
Checking tires presssure is nit gonna hurt or too much work.. Its just a push of a button..
Old Sep 4, 2015 | 10:15 AM
rbrylaw's Avatar
Exactly. I don't know why someone would wait for the tire pressure to be too low. Keep the tires happily filled with air, get better gas mileage and enjoy longer tread life. It's like the Staples "Easy Button!"
Old Mar 18, 2016 | 04:45 PM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
Every week or so I pull up the tpms display on the multifunction display. If its less than 32psi I check and service the pressure the next morning (cold).
Old Mar 18, 2016 | 05:20 PM
Luton Driver's Avatar
C Class 200 sport petrol auto
No one is mentioning about checking the engine oil. I did my first check after 1400 miles and the dip stick was bone dry. I had to put a litre in just to get to the bottom of the dip stick plus a futher top up to get the level to the top marker. Time will tell if I have damaged to the engine.
Old Mar 18, 2016 | 05:40 PM
Veteran: Air Force
Holy cow, Luton, thanks for the reminder. For sure, engine oil is much more important than tire pressure.
As a result of your post I'm going to get off my skinny *** right NOW and check my oil, at about 900 miles.
I recall a notation in the manual stating engine oil consumption could be as much as almost a quart in 600 miles. Perhaps we should pay attention to this info.
With a seven quart crankcase but two quarts low, I'm guessing no damage unless you drove the vehicle to RAF Lossiemouth and back...at speed.
Old Mar 18, 2016 | 09:00 PM
Mr. J's Avatar
C450, GLC43
Sometimes engine oil consumption can be higher in a new motor depending on break-in protocol.
FWIW, I check the oil in my vehicles weekly. I almost never need to add any but it's one of those habits I learned while driving beaters when I was younger.
Old Mar 19, 2016 | 05:54 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Oil level checking is not by sensor?
Old Mar 19, 2016 | 07:57 AM
MASSC450's Avatar
2026 GLE 53 Coupe
You're thinking BMW. My C300 has a dip stick, my wife's 2014 328i does not.
Just over 7,000 miles on my car now, oil level is still on full.
Old Jun 11, 2016 | 07:34 PM
nsure4u's Avatar
1996 S420
C300
Check everything. In the everyday rush of life, overlooking is human error. Check everything.
Seal the paint with Natty's blue or Mequire Black paste.
Keep it garaged, never park under a tree.
And for the professional finish, go on Amazon and buy a 4 layer cover with lock and cable all for under $50. And use it.
25 years later my '91 300sl new like new.
Best of luck sir😎
xrcyzr66 in Phoenix
Old Jun 20, 2016 | 05:37 PM
PeterUbers's Avatar
Old May 30, 2018 | 09:47 AM
ot1's Avatar
ot1
2006 E320 CDI
06 E class does not have a dip stick either, done by sensor with dash warnings, and oil level can be monitored while driving.
Old Sep 18, 2018 | 03:57 PM
Alex Vek's Avatar
C300 Bluetech Hybrid AMG Premium
Oil For C300 Hybrid 2015?
I want to put the best oil on my C300 Bluetech Hybrid AMG ...
Any recommendations?
Old May 13, 2019 | 10:29 PM
DaveW68's Avatar
Veteran: Army
2015 S550
