Burmester sound system: where to tap for non filtered signal?
Old Oct 27, 2015 | 08:25 PM
brann's Avatar
c300
Wanting to install a small subwoofer, and I need to tap the speaker lines. I imagine the Burmester system is heavily filtered, amplified, etc before it reaches the actual speakers.
Anyone know if the lines that come out of the head unit are unfiltered? The idea is to get a signal that does not have a high pass filter.
Thanks!
Old Oct 28, 2015 | 05:08 AM
vic viper's Avatar
S213
Tap into the lines to the foot well base speakers, this is what I plan to do when adding my sub as soon as a have time.
The amp is located in the right side of the trunk.
Old Apr 8, 2016 | 02:03 PM
markjervis's Avatar
2016 C300
Did anyone ever get their subwoofer installed? I'm looking to do this to my MY16 C300 with Burmester.
Old Apr 8, 2016 | 02:11 PM
Mike5215's Avatar
2016 C300
I'm about an hour away from picking up my 16, it got a sub installed as well of a bunch of other gear. You'd pick up sub from the channels for the two footwell subs, on the high (powered) side of the OEM amp. I'll ask the installer for the wire color codes of those leads off the amp.
Your new sub amp will need to accept speaker level inputs or you'll need line level converters to convert back to line level before the amp.
Old Apr 8, 2016 | 02:15 PM
markjervis's Avatar
2016 C300
Thanks. Color code or wiring diagram would be great. Do you know if the footwell subs are mono or stereo?
Old Apr 8, 2016 | 03:04 PM
vic viper's Avatar
S213
Only one sub if standard sound system, stereo subs left and right with Burmester
Old Apr 8, 2016 | 05:31 PM
Mike5215's Avatar
2016 C300
Well I went to pick up the car today and there's a problem with the Prima unit. They're replacing it tomorrow but in all the hoopla I forgot to ask about the wire color coding.
Old Apr 8, 2016 | 09:57 PM
markjervis's Avatar
2016 C300
No problem. Not doing the install yet. Just trying to get all the info I can to pass onto the installer when I do have it done.
