Remove Front Wheels
Old Nov 4, 2015 | 10:37 PM
donsalari's Avatar
Mercedes C 300
Remove Front Wheels
I know this sounds like a super basic question but I am trying to remove my front wheels and I simply cannot figure out where I should put the jack stand!
I tried to place it at multiple places but as soon as I start rolling it up, the plastic bottom starts to squeak.
Does anyone know where to place the jack stand for the front wheels?
This is what i have :
Amazon.com: Ultra-Fab Products 48-979006 24" Ultra Scissor Jack: Automotive Amazon.com: Ultra-Fab Products 48-979006 24" Ultra Scissor Jack: Automotive
Old Nov 5, 2015 | 08:26 AM
mikbar2's Avatar
2015 C300, 2015 F-350 Platinum, 1969 Mach 1 428cj, 2007 Roadking
There is a plastic pad on each side. Two for the rear and two for the front if it's a 2015. It would be helpful if we knew what your car is.
Old Nov 5, 2015 | 10:07 AM
donsalari's Avatar
Mercedes C 300
Yeah it's a 2015 C300.
The plastic pad wouldn't crack?
Old Nov 5, 2015 | 11:28 AM
mikbar2's Avatar
That's what they're there for.
Old Nov 5, 2015 | 12:24 PM
donsalari's Avatar
Mercedes C 300
Ok then. M gonna roll it up on the plastic. Thanks!
Old Nov 5, 2015 | 12:52 PM
NovaOne's Avatar
2021 CLA 250
Not so fast!
The jacking point is plastic but it's intended to be used with a specific type of jack pad, that's why there's a rectangular inset on it rather than being perfectly flat.
Because of this rectangular inset, your jack will most likely not be able to make proper contact with the jacking point. They sell this:
Amazon.com: Metal Jack Pad Adapter by BMS - 2000-Present Mercedes Benz Vehicles: Automotive Amazon.com: Metal Jack Pad Adapter by BMS - 2000-Present Mercedes Benz Vehicles: Automotive
I recommend getting this to be safe.
To add, I just used a block of 2x4, but this adapter is safer.
Old Nov 5, 2015 | 01:04 PM
donsalari's Avatar
Mercedes C 300
Originally Posted by NovaOne
Not so fast!
THANK YOU!
I will look into that.
And I really appreciate for the amazon link!
Old Nov 5, 2015 | 01:32 PM
mikbar2's Avatar
I use wooden blocks there with my two post lift and have never had a problem. To use that on my two post lift would also require four of them which equals 80 bucks.
Old Nov 5, 2015 | 01:37 PM
donsalari's Avatar
Mercedes C 300
just to be sure. this is what i have. please check attachments.
Attached Thumbnails Remove Front Wheels-img_2998.jpg   Remove Front Wheels-img_2999.jpg
Old Nov 5, 2015 | 01:39 PM
donsalari's Avatar
Mercedes C 300
cool i can try that as well. you used it on 2015 c class?
Old Nov 5, 2015 | 02:45 PM
mikbar2's Avatar
Yes, It's in my sig.
Old Nov 5, 2015 | 02:47 PM
louiet3's Avatar
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
If that is the MB OE jack then it would fit easily in the recess area for lifting. I have a similar jack for my 2012 GLK350 and have used it several times without any issue. My 2009 C300 has a different jack but it also has a recess area that I have used without issue as well.
Not being mean but did you check you owner's manual as there is a section on how to use the jack.
Also the picture you have in your original post doesn't seem to be the original jack but your most recent post picture looks OE.
Read your manual, use your OE jack and you should be good to go.
Old Nov 5, 2015 | 05:12 PM
donsalari's Avatar
Mercedes C 300
Yea I checked the manual but it didn't say much.
I got the jack from a friend who has a 2013 c class.
So maybe I am good to try it out.
Old Nov 5, 2015 | 06:39 PM
NovaOne's Avatar
2021 CLA 250
Yea, if that's an OEM jack, then it will definitely fit in the jack point inset. You would not need any other pads or anything.
The jack pad is only for those of us without an OEM jack, such as a hydraulic floor jack.
Old Nov 5, 2015 | 06:46 PM
donsalari's Avatar
Mercedes C 300
Brilliant. Thank you so much guys! I am gonna paint my wheels tonight!
