Airmatic failure
Old Nov 19, 2015 | 03:53 PM
bartola's Avatar
CLA-250, C-300
Airmatic failure
Not much noticeable but the gap - probably bad struts
Dealer has not called, hope the don't try to blame the links. I did not have time to swap
Old Nov 19, 2015 | 04:03 PM
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
Yikes. Hopefully the links didn't have anything to do with it. Can't imagine the struts going bad already, probably a compressor.
Old Nov 19, 2015 | 05:15 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Eeek.. Definitely not dabbling with links now...
Old Nov 20, 2015 | 12:27 AM
vic viper's Avatar
S213
Er?, where is the problem, I can see it in the pics?
Old Nov 20, 2015 | 05:39 PM
bartola's Avatar
CLA-250, C-300
Dealer said there are still looking, want me to come in and drive with them. no mention of links, but no car yet.
We will see, I will try to get over today.
Old Nov 20, 2015 | 06:58 PM
*Knowledge*'s Avatar
The Infamous C450
I must be missing something here but what are we looking at in the pics?
Old Nov 20, 2015 | 07:16 PM
PeterUbers's Avatar
Maybe that's why the dealer wants him to come and identify the problem
They can't see anything wrong either
Old Nov 20, 2015 | 09:03 PM
bartola's Avatar
CLA-250, C-300
Best I can describe it, it is like a subframe crack or control arm is about to break.
compare the first picture in the post with the one below. In the 1st picture the car is in sport+ mode before putting on flatbed.
In the flatbed it looks normal because they tie it down and force the suspension down.
I have experienced both. But not discarting and would be very happy if there is nothing wrong with it.
Old Nov 21, 2015 | 04:05 AM
ManiacGT's Avatar
I don't think I understand this post, are we looking at a ride height issue, placement of Wheels in the Arches front to back what is the actual problem, is it noise when driving?
Old Nov 23, 2015 | 03:10 PM
BlackjackM's Avatar
So it's basically a wild guess that Airmatic failed, this after installing aftermarket lowering links?
Old Nov 23, 2015 | 10:28 PM
Glyn M Ruck's Avatar
Super Moderator
This worry is poorly explained. Airmatic failure is very noticeable with uneven ride height somewhere on the car. Down at one or another corner.
Old Nov 24, 2015 | 01:42 AM
bartola's Avatar
CLA-250, C-300
Yes, I am sorry I can't modify the title. One of the struts has a leak, front right - dealer replaced.
Old Nov 24, 2015 | 08:11 AM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
it was leaking but the ride height increased?
Old Nov 24, 2015 | 10:58 PM
bartola's Avatar
CLA-250, C-300
That is what they said, and it was the left my bad, I guess the right is trying to compensate? idk.
Anyway, car is back on the road, just had a bad week, I drove the CLA (wife's) to work and on the way back I hit a deer (livermore, CA) - It was surreal -
My wife was a little upset!
Year: 2014 Style: 4D SED VIN: Mileage In: 23633
Make: BENZ Color: white Mileage Out:
Model: CLA250 License: Job Number: Vehicle Out:
Line Ver Operation Description Qty Extended
1 E01 FRONT BUMPER & GRILLE
2 E01 Remove/Install R&I bumper assy 1.8 Body
3 E01 FRONT LAMPS
4 E01 Remove/Replace Aim headlamps 0.5 Body
5 E01 Remove/Replace LT Headlamp assy 1 999.00T OEM 0.6 Body
6 E01 HOOD
7 E01 Repair Hood 2.0 Body 2.8
8 E01 Add for Clear Coat 1.1
9 E01 FENDER
10 E01 Remove/Replace LT Fender 1 386.00T OEM 3.1 Body 1.8
11 E01 Overlap Major Adj. Panel (0.4)
12 E01 Add for Clear Coat 0.3
13 E01 Add for Edging 0.5
14 E01 Remove/Replace Deduct for Overlap (0.5) Body
15 E01 Remove/Install LT Fender liner CLA250 0.0 Body
16 E01 Remove/Replace LT Emblem 1 29.99T Other 0.2 Body
17 E01 PILLARS, ROCKER & FLOOR
18 E01 Remove/Install LT Rocker molding w/o sport pkg 1.1 Body
19 E01 WHEELS
20 E01 Remove/Install LT/Front R&I wheel 0.1 Body
21 E01 Sublet wheel alignment 1 75.00 Other
22 E01 MISCELLANEOUS OPERATIONS
23 E01 Remove/Replace Cover car/bag 0.2
24 E01 Remove/Replace corrosion protection 1 10.00T Other 0.2 Body
Subtotal 2,764.39
Old Nov 25, 2015 | 11:39 AM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
3 E01 FRONT LAMPS
6 E01 HOOD
9 E01 FENDER
19 E01 WHEELS
Subtotal 2,764.39
Sorry to see this. Maybe you should go home and hang low for a few days so nothing else happens to your cars......
Old Nov 25, 2015 | 12:52 PM
parkwood's Avatar
EQE 500 4MATIC replacing EQC 4matic AMG line P
3 E01 FRONT LAMPS
6 E01 HOOD
9 E01 FENDER
19 E01 WHEELS
Subtotal 2,764.39
Ouch! I did the same in my c250 estate a couple of months ago. Really nasty experience. I hit the poor creature fully broadside to the front of the car fortunately killing it. Have the shoulder in my freezer after a fellow motorist took the carcass away.......this being france it was not going to go to waste!
My bill inc tax was 820 euro. No painting was needed just replacement of the 3 grills, no plate and carrier, realignment of 1 headlamp unit and recalibration of the 360 camera after the grille replacement. In retrospect the car survived the impact amazingly well and i think slowed more than i realised with its collision protection system.
Not a good time for you hope your luck improves!
