Aftermarket Sound System
I am considering upgrading my standard audio in my C200 to a much better aftermarket system. My budget is around $1500, and would prefer if it was $1k if possible. I love hifi sound and the standard audio doesn't satisfy that. I also heard that the Burmester isn't the best, so I want something better than both. Love a good bass, and overall balanced sound. Anyone who could share their experiences to how I could find speakers, tweeters, etc. from a good brand without installation - I will try to find a local service center who could do it for me because I am not familiar at all with installations and fixing.
similar to this one
http://www.rockfordfosgate.com/products/details/r1-1x10
The Prima unit connects to your laptop for configuration. The C suffers from excessively bright midrange, which is the result of having 4" drivers x 4 in the cabin and no proper woofers. Instead the subs in the footwell have to play "up" quite a bit into midbass territory which can make them sound loose and boomy.
The precise control the Prima provides is ideal for a set up like this. You would assign each speaker a channel:
1) left front mid
2) left front tweet
3) left front sub
4) right front sub
5) right front tweet
6) right front mid
7) right rear mid
8) left rear mid
The unpowered 9th channel could be sent out to a sub box and amp in the trunk, or left open.
For each speaker you would have control of level, crossover points, equalization, and delay. The Prima installs after the factory amp and before the speakers, so you still have 100% COMAND functionality and control.
The Prima is around $900, and install would run you another $500.
Here's a screen grab of one speakers config screen:
1) left front mid
2) left front tweet
3) left front sub
4) right front sub
6) right front mid
7) right rear mid
8) left rear mid
similar to this one
So after playing around with a 3rd party EQ app I've determined that the Prima 8.9 alone is not going to cut it. The 4" mid drivers in the doors just don't have the power handling capability you'd need. Typically it should be close to impossible for the stock amp to overdrive any of the stock speakers, but that's not the case here.
I do think the stock subs and tweets are usable, so it would just be a question of finding a heartier 4" woofer. One way to go is a 4" two way component set up front like the Focal KRS100 but those are $749 a set. Not a lot of choices in 4" components I'm afraid. I'd suggest a 4" coaxial (tons of those out there) like the MTX here are $79 a set. I have a pair of these in the rear deck of my S Class replacing the stock 4" Harman/Kardon surrounds. They're quite a bit smoother and warmer, with more power handling.
http://www.crutchfield.com/p_236THND...2768385&awdv=c
Two sets of those would do it. Don't sweat the extra tweeters. You can cut them back with the Prima.
If you want to spend $749 on a set of speakers, put the Focal KRS100 in the front doors. Not so much for the 4" mids, but the tweeters that come with the set are phenomenal. I'd also want a small sub box and amp in the boot. I'd want a sealed box, no more than a 10" and ideally two 8".
