C450 Muffler delete exhaust video
I have the base note magnaflow are known for, the gearchange rasp is alot better, the low rpm mild grumble is there and the deeper rasp is a little there under load and higher rpm.. off load and at lower rpm you barely hear it.. perfect for me..
IT DOES NOT HAVE THE METTALLIC RASP OF FOR EXAMPLE THE ARMYTRIX SYSTEM.. some like that.. i do 2 hrs highway cruising a day so its not right for me..
There was a tiny bit of drone at 2k rpm (100kmh) on the highway, but with liberal dynamat in the back end of the car thats 100% gone.. ie it was a resonance of the trunk / wheel well rather than a note of the exhaust so to speak..
I also had the flanges added to the originals if i ever want to return it to stock.. i could also get a striaght through tube made to bolt on on one or both sides.. but i have to say the current level is ideal for me...
This thread got me interested in an electric cutout system.
There is some drone, but unless youre sensitive to it, it should not bother you.
I ran my car on the 1/4 mile before and after the muffler delete. I actually managed to get .1 seconds better after the muffler delete. this is probably due to other conditions, as its not a big difference, but you can be assured at least there was no loss in performance.
What size magnaflow mufflers did you get? trying to figure out OEM exhaust pipe diameter size. Thank you
