Disapointing fuel economy - C450
I now have 1800 km's on my C450 and I'm getting some pretty low fuel economy, much lower than expected and light years away from EPA ratings.
Even when I drive like a grandmother in Eco mode, I still don't get good mileage.
My experience, based on looking at the Consumption screen, which indicates L/100km fuel consumption for every 60 second interval. My commute is about 20 minutes, with the first 6 minutes or so being in stop start city driving. The last 14 minutes is freeway, about 110km'h (70MPH ish). It seems like the vehicle is sucking fuel hard when the vehicle is first started and eventually the consumption bars start to stabilize to where they should be (around 9 L/100KM)...
The problem with that is by the time I get to my office, most of the drive was spent burning a lot of fuel... It seems like you have to go on really long drives to get decent fuel mileage on this, as the first 10-15 minutes is uneconomical...
Is this the ECU mapping to protect the engine while it is warming up by sending a rich air/fuel mixture? Temperature was warm here today (around 70 F) and my engine was at operating temp in no time, say 3-4 minutes... It seems like it is leaning out the mixture way too long after startup, which is killing my mileage...
Anybody have any insight into how this works or is mapped?
My average fuel economy is 13.5-14 L/100... not good at all, much worse than my previous vehicles and my previous vehicle's EPA ratings were worse than the C450 so it doesn't make sense to me...
I feel like my dealer won't be very helpful when I approach them, so trying to arm myself with info beforehand...
Obviously, everything comes in to play. AC use, 75 mph on highways, stop and go, etc.. but it's not where I thought it would be at 2400 miles.
Will keep an eye out as mileage improves but still find it weird that it's so thirsty the first 10-15 minutes of run time...
Tyre pressure
Tyre wear (alignment)
Brakes binding
If these are all to spec, once the vehicle is run in then measure actual mileage (record fuel in over miles etc).
Then if still substantially over expectation approach the dealership...
Some people also live in very hilly areas, have heavy right feet, run lower octane fuel, always run the ac or electrical heaters to the max... All these need to be realistically factored...
EPA plus 20% is apparently considered normal...
Best of luck, hope it settles down or you find any problems...
that said, i don't think anyone buys a c450 for fuel economy and i'd be more than happy with 21 combined when i get one (c43 coupe anyway).
i'd imagine the 9 speed might help a little bit, but yeah if you don't drive like you are on eggshells almost no car gets epa milage other than diesels
On another noted, yes I noticed that it sucks gas however since we have digital readings and not analogue its not easy to really gauge the fuel use per tank.
even with the higher performance of the C450, I figured the 7speed (which I did have in the C300 as well) and the SS and some other elements would at least get me similar or close to EPA for the car. Sadly, I'm running about 15-20% BELOW EPA ratings on the car at this point.
