COMAND 10.25" Screen Upgrades
Rating: Thread Rating: 3 votes, 5.00 average.
Old Feb 2, 2019 | 06:44 PM
  #476
Christion's Avatar
2016 c300
AA on 10.25" screen
This is how android auto looks on the 10.25 4/64gb screen with the "allow 720p/1080p video outout" settings selected in the AA developer settings.
Old Feb 2, 2019 | 06:55 PM
  #477
Christion's Avatar
2016 c300
Originally Posted by motomd
Does someone have a link to where I can buy the usb aux adapter? I only have BT, thanks
anyone have luck with this one?
http://www.unichip-tec.com/h-pd-135....pp=0_848_31_-1
I would suggest contacting someone like carlife mall to see if you can buy it from them. They sent me both the usb and bluetooth sources, per my request. The usb adapter is on the left and the bluetooth box is on the right.
Old Feb 2, 2019 | 06:59 PM
  #478
Christion's Avatar
2016 c300
do you have the files? It doesnt seem like this will fix the issue of the hissing or lower audio quality. Have you seen a big improvement. I got mine from a aliexpress seller and they are no longer on aliexpress. Thank you.
I made the mistake of buying my first screen on aliexpress and it was a huge mistake. My second screen was from Carlife mall and the difference was night and day, and there's extensive after sales support. The screens are cheaper on aliexpress because you don't get much support. My Carlife mall screen came with instructions and they always provide new updates. They also have a ton of helpful YouTube videos and they quickly reply to inquiries.
My 9.33" screen came damaged from an aliexpress seller, the screen quality was poor, it was a pain to get any help, and they gave me some copycat carplay dongle that had a ridiculously slow charging time. The fake carplay dongle had it's own apk app that looked completely different than the usual one, and it wasn't authorized to work on the real carplay apk app that came with my 10.25 screen. The real McCoy is the Carlinkit dongle that comes in a retail style box with instructions.
Old Feb 4, 2019 | 12:40 PM
  #479
motomd's Avatar
glc
how do you like the USB adapter, any issues at all with it? the bluetooth adapter is crap in terms of quality
Old Feb 7, 2019 | 02:45 AM
  #480
sentralfyr's Avatar
2015 S205 AMG
Whith help from TorbenK, I was able to connect my Bluetooth OBDII to my screen.
First of all, go to settings,software version,press the green gear upper right, then press 8888, press Menu Icon, on the lest you find a field you can scroll down (find OBD and double click)
Go back to the homescreen ,Do a restart ,find OBD and then pair your device.
I have tested With tha APP Torque and RealDash.
https://i.imgur.com/0HRR2qB.mp4
https://i.imgur.com/PYRtl8u.mp4
Old Feb 7, 2019 | 10:45 AM
  #481
TorbenK's Avatar
C220D W205 Estate
RealDash is looking cool...!
Old Feb 7, 2019 | 11:35 AM
  #482
sentralfyr's Avatar
2015 S205 AMG
Thanks, but i need to know excactly what i can read from Mercedes OBDII connector, There is lots of things that do not work yet.
I also need to know the gear ratio on the 7G Tronic
I also need to know Mercedes W205 PID
Here is a answer from RealDash.
This is our default answer if you are using OBD2:
In OBD2 connection, Gear is calculated per speed and your vehicle gear ratios:
Go to RealDash 'Settings->Units & Values' and set Vehicle speed source as 'ECU Speed Sensor'
Go to Garage, open vehicle door and tap gear shifter
Enter your vehicle gear ratios. Use 0 on unused gears.
Tap vehicle tire and set your vehicle tire size (driving wheel).
While fuel level is part of OBD2 standard, many vehicles do not send this information to OBD2 port.
By default, fuel level is set to 'Calculated'. You can adjust the fuel level from Quick Settings ('Gear' icon on bottom right). While fuel level is part of OBD2 standard, many vehicles do not send this information to OBD2 port. You can still try to map OBD2 fuel level on RealDash:
1. Open 'Settings->Units & Values->4th page'
2. Find 'Fuel Level' and change the mapping to 'ECU Specific->OBD2: Fuel Level'
Turn signals and other indicators are not part of OBD2 standard, but there are basically 3 ways to get turn signal and other indicators work on OBD2 vehicles.
Use vehicle vehicle specific PIDs. If PIDs are known, you can add those into RealDash OBD2 values by modifying and importing the XML file. See 'Customizing OBD2 Communications' from our manuals: realdash.net/manuals/customizing_obd2_communications.php
Use extra IO box, like SPLeinonen DashBox (www.spleinonen.com). These solutions have extra inputs that can be wired to indicators.
Use DIY solution like Arduino with our open RealDash CAN protocol to transmit indicator statuses to RealDash. See 'RealDash CAN' from out manuals: realdash.net/manuals/realdash_can.php
If anybody Knows enything about this, please feel free to Answer
Old Feb 18, 2019 | 03:13 PM
  #483
TorbenK's Avatar
C220D W205 Estate
If anyone is needing the V35 update, you can find it here for 7 days from 19-02-2019:
https://fil.email/uPZ3O0UZ
https://transferxl.com/08v8Bs4Nkx7Pc
https://www.plustransfer.com/downloa...3b3b0acb47f0c6
https://megaupload.nz/ZbMd00ufb3/10....5_20190104_zip
What is included (10.25 - 1280x480 - dated 2019-01-04):
- UI upgrade: 3562.bin + 3562.upd
- MCU upgrade: ts24x.bin
- CAN upgrade: can_app.bin
- Boot animation update: bootanimation.zip
- Installation guide: HOW TO.jpg
Do anyone know if the software for the W205 will fit a A class version also - upgrading from V1?
Old Feb 19, 2019 | 09:51 AM
  #484
zippi's Avatar
S205
If anyone is needing the V35 update, you can find it here for 7 days from 18-02-2019:
https://we.tl/t-Dj4UQkby2B
What is included:
Hello,
Thanks for the link. But it doesn't work. Could you please reupdate again ?
Does this update suit for thr 10.25 screen with Android 6, of for the 9.33 screen?
Regarding your question, i haven't the answer, but i guess that the difference between 10.25 screen for w205 and A class is in the holder?
Cheers.
Old Feb 19, 2019 | 11:04 AM
  #485
TorbenK's Avatar
C220D W205 Estate
Try new link:
It is for the 10.25 /1280x480
https://megaupload.nz/ZbMd00ufb3/10....​​
About the A class I could be affraid that there was an issue with the CAN connection, unless the software/display has multiple support...
Old Feb 19, 2019 | 01:43 PM
  #486
zippi's Avatar
S205
Try new link:
Thank you, the new link works.
​​​​​​​Do you know if the upgrade will factory reset the screen ? Or it keeps the installed applications ?
Yeah, i think you are right regarding the a class upgrade. The can is surely different than the w205.
Old Feb 19, 2019 | 02:08 PM
  #487
TorbenK's Avatar
C220D W205 Estate
Yup, it do a factory reset...
Old Feb 24, 2019 | 12:10 PM
  #488
Ptraslav's Avatar
Mercedes W212
PLEASE HELP
Dear,
I just entered this forum because I need if someone can help me with a problem of my radio that installs (my Mercedes is a W212 of the older NTG) it worked very well and suddenly the error started "THE IU APPLICATION OF THE SYSTEM HAS STOPPED "He does not let me do anything. Beforehand thank you very much.
Best regards
Old Feb 24, 2019 | 01:05 PM
  #489
sentralfyr's Avatar
2015 S205 AMG
Originally Posted by Ptraslav
Dear,
Best regards
Try to reset your screen pressing this button
Old Feb 25, 2019 | 11:09 AM
  #490
Ptraslav's Avatar
Mercedes W212
Dear,
Thanks, however I made an update left by TorbenK, and it served me. First of all, Thanks.
Best regards
Old Feb 25, 2019 | 10:43 PM
  #491
IamET's Avatar
C300
Try new link:
Hi all,
Can this update be applied to 10.25" V2(2G RAM/32G ROM) and V3(4G RAM/64G ROM)?
Thanks.
Old Feb 27, 2019 | 12:55 PM
  #492
TorbenK's Avatar
C220D W205 Estate
Dear,
Best regards
W212. Interesting..did you just update the UI or the MCU and CAN also?
  #493
TorbenK's Avatar
C220D W205 Estate
Originally Posted by IamET
Hi all,
Thanks.
It should. Mine is a V2
Old Mar 3, 2019 | 04:44 PM
  #494
TorbenK's Avatar
C220D W205 Estate
V36 - 4G_UI02-2-1280x480_v36_20190221_8.1
https://nofile.io/f/jqz1mn0y5ap/36.rar
Old Mar 4, 2019 | 10:19 AM
  #495
Ptraslav's Avatar
Mercedes W212
Dear:
Only the interface did not dare the rest.
A question to connect the rear camera in which fuse I must do it.
Best regards
Old Mar 4, 2019 | 10:39 AM
  #496
TorbenK's Avatar
C220D W205 Estate
Fuse box in the trunk.
See the piggy back in the bottom right (this is my W205!)
Old Mar 5, 2019 | 06:29 AM
  #497
sentralfyr's Avatar
2015 S205 AMG
Latest Software Update V36(Updated file)
http://www.mediafire.com/file/wclsft...grade.rar/file
BootAnimation
http://www.mediafire.com/file/l988wf...tAnim.rar/file
Old Mar 7, 2019 | 02:05 PM
  #498
Ptraslav's Avatar
Mercedes W212
thank you. Best regards
Old Mar 7, 2019 | 08:45 PM
  #499
Ptraslav's Avatar
Mercedes W212
Dear,
Regrettably, the iGo maps were erased, you know where I can download them from.
Best regards
Old Mar 8, 2019 | 01:46 AM
  #500
sentralfyr's Avatar
2015 S205 AMG
Dear,
Best regards
Go to APPS, APKINSTALLER and find IGO, then install
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
