Michelin Super Sport Question
2016 C450 AMG
So I've been hearing people basically say yet rid of the run flats asap. Everyone also seems to agree the Michelin super sports are what I should get.
Tirerack.com says the super sports aren't an option for factory 18 rims.
My sizes are
Front 225/45 R18
Back 245/40 R 18
Per tirerack the only difference in the tires is they are zr18s which I believe are fine. Isn't that just the speed rating differences?
Also, does anyone have thoughts on keeping them staggered? Pros or cons?
Or does anyone suggest an alt tire arrangement on the factory 18 rims.
Thanks!
My sizes are
Front 225/45 R18
Back 245/40 R 18
Thanks!
I'm on MPSS and factory 18" staggered (7.5,8.5) and no issues. On Tirerack, when selecting your vehicle, make sure you choose Sport as an optional configuration.
I do know the fronts are discontinued and Tirerack was the only place I could find them.
Will be pulling my run flats immediately after reading all the stories of the Conti's going bad under 10,000. I have a 3 year lease and there is no way I am buying 3 sets of tires while I have this car.
OEM Conti's are getting stored and reinstalled the week I return it. I'll run Eagle F1's if I have to.
Yeah, the ride is noticeably smoother and quieter on the MPSS vs the run flats, and they last longer. I've used them exclusively on my previous S Classes and on the C, with AirMatic, the car feels like a little S.
245 may not fit on the front wheel, it may not be in the approved safe range for mounting if it does "fit", and finally it would bulge out the sidewall visually as well. OTOH if you got two more rear wheels and put them on the front with 245's it might work out better. It's not a whole lot wider so I don't think it would rub, but you would have to check clearances and offsets to make sure.
2015 C300 sport 4Matic
So if you guys are not running the run flats anymore, do you guys have anything for use for emergency? Just wondering so I'll know when I change the run flats that I currently have. Thanks.
Good question. I wonder if there are temp spares we can buy that'll fit. I saw one guy a few posts back said something about buying a spare and throwing it in the trunk/boot.
I'm liking the Continental ExtremeContact DWS 06 (non-runflats) that I had the dealer install in place of the standard run-flats as part of the purchase deal.
You might compare those if they come in your size.
Mine are 19s. I really like them after 10K miles.
2021 E450, 2020 C43, 2015 C300, 2007 C280
MOE run-flats?
One thing is seldom clear to me when owners complain about run-flats: are they talking about "MOE" ("Mercedes Original Extended") run-flats, or not? MOE run-flats have a better ride, but reduced limits on speed and range after loss of air. They also have the M + S rating ("Mud and Snow"). The stock, as-delivered tires will be MOE run-flats, but in their dissatisfaction, some owners may have already swapped the original MOE tires for non-MOE run-flats. Their dealer may even have done it before delivery. (For more information on MOE tires, go to Mercedes-Benz Original Extended Tires (MOExtended or MOE) at TireRack.com.
I plan to store mine till it is time to return the car. Otherwise I could feasibly need to buy 3 sets (at about $1200 per set) before I return the car. IMO, unless you are driving your car hard, the OEM tires should last the duration of a lease or at least 30,000 miles.
EDIT: According to the TireRack website, the Michelin Pilot Super Sport are the highest rated "summer" tires and the Michelin Pilot Sport A/S 3+ are the highest rated "all seasons".
gfmohn (08-05-2016)
Tire Rack consumer survey of the three MOE tires available as original equipment
I cannot speak for the others, but I am talking about the MOE tires you referenced here. There are numerous accounts of these tires either failing or simply running out of tread depth, at or below 10,000 miles. This is unacceptable, if for no other reason than they are too expensive to fail so quickly. Compound that with the fact that my car is a 36,000 mile lease. These tires also happen to be the 2nd lowest rated tires (when you plug the C450 into the configuration tool) on TireRack, just above the Kumho Ecsta, which are the worst rated in this tire range.
Super Moderator
Out of interest. I have always been a Michelin PS2 fan on most Benz chassis. Have just fitted the new Pilot Sport 4's to my CLK & I'm most impressed. Dead quiet, comfortable, excellent turn in etc. Great summer tyre. I can't talk about life yet but that has never been my major consideration. I have yet to find a run flat I could live with.
My first S (06 S500 AMG Sport) had MPSS as OEM, but they were so expensive I kept trying "off" brands...Sumitomo, Continental DW. I'd eat up rears like crazy. Seemed like I'd just bought a set and the next morning they were to the wear bars again. Finally my SA told me to just get the Michelins and bite the bullet. Totally different feel, in the best possible way. I swear by them. And in ten years and three S Class, and a couple hundred thousand miles, I never had so much as a flat, much less a sidewall rupture from a friggin rock or pothole. Roads have rocks and potholes. Your tires should not explode when they encounter them.
