2015 C400 BMS Tuned - Quarter Mile
Old Aug 25, 2016 | 10:20 AM
JoeyB Benz's Avatar
2018 C63 AMG & 2017 C43 AMG
12.7 @ 108 !
Vid 1
Vid 2
DA +1900 at Englishtown NJ
Very Happy with my Tune ONLY C400 4MAtic
** The SCALE is with me in the car. I weight 200 lbs
Attached Thumbnails 2015 C400 BMS Tuned - Quarter Mile-img_20160824_195631315.jpg   2015 C400 BMS Tuned - Quarter Mile-photo-aug-24-9-24-42-pm.jpg   2015 C400 BMS Tuned - Quarter Mile-img_20160824_224641813.jpg
Old Aug 30, 2016 | 11:17 AM
TopGun32's Avatar
Great ET
was it warm and humid? 12.7 usually good for 110/111 trap speed but every track is different
mix any race fuel or E85
on my jb stage 1. I can hit about 14lbs boost on map 2 with 3 gls of E85
If you data logged your runs. Post your amount of boost please.
Old Aug 30, 2016 | 11:28 AM
JoeyB Benz's Avatar
Originally Posted by TopGun32
Great ET
It was Warm 80s August here in NJ
I only have Stage 1 on pump 93 gas.
How do I datalog runs?
Old Sep 1, 2016 | 08:24 PM
TopGun32's Avatar
from jb1 run long usb cable from engine bay to inside the car. Typically open door and hood and let the cable slip through.
download the jb4 software from n54tech.com load to a lap top.
hook up to lap top while car is off and make sure you install the software and port correctly.
once hooked up. Turn car on. Open the software. Change the map to 2 and there will be a drop down option to data log.
Run the car strong and then save the data log file
Old Sep 2, 2016 | 04:58 PM
JoeyB Benz's Avatar
Do I have to Run E85 Mix? I only want to run 93 Pump Gas.
Old Sep 6, 2016 | 11:33 AM
TopGun32's Avatar
Map 2 is for pump gas. 91/93 oct.
e85 or race gas small mix will only help to produce a bit more power.
map 2 is te best map
Old Sep 7, 2016 | 11:11 AM
kschenc's Avatar
c250
can I know your map 2 is connect with brown wire? or all four connectors? pls advised?
Old Sep 7, 2016 | 11:07 PM
TopGun32's Avatar
brown wire issue is for c300. For the v6 we get to connect all connectors.
Old Sep 24, 2016 | 03:01 PM
InTheBenz0's Avatar
GLC 63 S AMG / Corvette C8 / Jaguar SVR
Hey Joe,
I got my VR Tune on my C450... cooler weather seems here to stay. Let me know when you are around would love to see the BMS tune vs the VR Tune.
I believe the VR Tune connects to more things,
• Boost pressure sensor
• Fuel Pressure Sensor
• Manifold air pressure
• Camshaft position sensor
I think the JB BMS tune connects to 3?
Old Sep 26, 2016 | 09:10 AM
JoeyB Benz's Avatar
Originally Posted by InTheBenz0
Hey Joe,
Yes Shoot me a DM or Text 732 513 1919
Old Oct 3, 2016 | 02:25 PM
foxberry's Avatar
C450 AMG
Hey Joe,
Hey guys - would love to throw the AMR tune into the mix as well...let me know if you guys schedule a day to run out at Raceway Park...I'm only 15 min away from there.
Old Oct 27, 2016 | 09:21 AM
JoeyB Benz's Avatar
NEW PB 12.689 @ 109.98!
https://mbworld.org/forums/c-class-w...ml#post6953279
