Dynamometer Mode
Old Sep 7, 2016 | 08:47 AM
oldman&theC's Avatar
2016 C450
Dynamometer Mode
I have been trying to enter the dynamometer mode and was successful twice,but can't seem to do it consistantly. I reviewed the U tube video's but some things are not clear.
1-In switch position 1 I get the odometer readings
2-Do you hold the "call" button & the "ok" button at the same time?If not which do you hold first & how long do you hold it before holding the other button.
The reason I am curious about the Dyno mode is I think I can improve the acceleration times in the dyno mode because all traction controls are off.The times I was able to enable the dyno mode I noticed the start seemed faster(less hesitation).Any help would be appreciated.
Old Sep 7, 2016 | 07:42 PM
DBOC205's Avatar
W205 C250BT
It's a sequence (press & hold call, then pres and hold oK). I think where most people go wrong is that they have the car running. You need to have the car in ignition mode only - you won't reach the service menu when the car is running. Turn it off completely, then follow the steps in the video - you'll get it.
Old Sep 7, 2016 | 08:05 PM
ItalianJoe1's Avatar
2003 CL 600
Yeah there has to be a half-second delay between pressing the call button, then the ok button. If you press both at the same time you won't get anything.
Old Sep 7, 2016 | 10:57 PM
uptownman's Avatar
Past:2010 ML63 AMG, 2011 C63 AMG, 2011 E63 AMG, 2015 C400 4matic & 2014 CLS550 4matic. Now: 2017 C43
Awesome!
Didn't even know we could do this!
Old Sep 8, 2016 | 05:30 AM
2016 C450
Originally Posted by uptownman
Awesome!
It might be worth trying the" Dyno Mode" at the drag strip.I noticed that the response at the start seemed faster.If you were already getting wheelspin the "Dyno" mode may not be of any help.
