Weird command screen failure
Well today I was driving and suddenly the screen did some really weird colors.. I looked at it and it started doing some crazy lines throughout the whole screen and suddenly the music shut completely off. So I tried to restart it and it didn't work. After a little while it restarted automatically and I tried to connect my phone via bluetooth. I couldn't even select bluetooth it didn't give me to option and when I tried to do it through "connect last played device" it shut off again. So I parked my car went in a store and just left it off for a little while. I came back and I still couldn't connect my phone neither was the radio working. About 5 hours later I tried it again and for some reason it started working again.
I actually captured what happened on video and I will have the link down below.
So my question is, did someone here had a similar issue to that?
Should I take it back to the dealership and ask them what happened? Because I am scared it will happen again.
I never had any issue like this before so maybe it was a one time thing but I will for sure keep an eye on it and see what happens next.
Thanks in advance and have a great day!!
I never had any issues like this with a C class before and it worked totally fine the whole time so I don't understand why it just came out of nowhere....
Since I stopped charging via USB, I haven't see that "white strips screen of the death".
Marius Weber
I think you should take the car back to the dealer and yes I've been dealing with a similar issue: While driving, command shuts down-no radio, no navigation, no phone,no CD. However,the screen does not show lines as you describe and I was not charging my phone. I can change the image on the screen from radio, to nav to phone but nothing responds to any commands. Then after parking the vehicle overnight or sometimes just for a few hours, the system will work. This started about one year ago. I've had the vehicle back to the dealer 5 times now with another appointment booked in a weeks time.
On the first visit I was told they can't fix what they can't see. So I drove the car straight to the dealership the next time it happened while it was happening. Many tests were done and a computer software update was installed. System was fine for a few weeks and then problem resurfaced. On the third visit I was promised a new command system which had to be ordered and was installed on my 4th visit. This was last summer(2015) & this issue did not occur again until this summer. So back to the dealer for the 5th time Aug 2016. This time the memory was erased and programs reinstalled. Problem resurfaced 3 weeks later.
I have tried several "fixes" that I found on this forum:
-turning engine off, waiting 1 minute and turning it back on
-turng engine off AND locking the car
-pressing the eject button on the CD and waiting 60 seconds
No success.
I believe outside temperature is a factor as the problem only occurs on very hot days. I have only 8400 km on the vehicle and only 4000 km since the replacement command system was installed.
Does anyone know of a solution to this problem? Thanks
What I found was that as soon as Bluetooth connected with my iPhone, I lost the system audio. Everything was normal until it connected, then the audio was lost. I turned off my iPhone completely and the audio was fine. When I turned the phone back on it reconnected, everything was normal and this never happened again. I had my dealer check it out, but no codes were thrown and no updates were available.
Some COMAND issues are real electrical malfunctions, but in my case the iPhone connection was the culprit ... and it only happened that one time.
Did anyone here manage to fix this? I’m guessing the solution above didn’t fully work because mine got progressively worse. Had it happen and then didn’t have again for many months. Now it happens every time I turn on my car. Takes about 30-45 seconds for the screen lines to start appearing. Then I have no choice but to hold the power button to reset it. Any ideas?
Hope this helps someone else!
Note: the SD NAV card I bought was the one from Amazon. Lots of reviews so I trusted it. Only lasted a few months.
Has anyone had that kind of issue or do you know how to reset the system to factory defaults?
I tied uploading an image here but it is getting stuck at 90%...weird.
Thank you!
I appreciate the input.
So I think I fixed it. White lines of death would come up every time I stated the car, around 30seconds in. It would require me to hold the power button to reboot the system. I had to repeat this reboot at least 2 times until the radio would stay on. So admittedly this was happening ALOT. I can’t believe I didn’t think of it before but I removed my navigation SD that I knew had already malfunctioned a long time ago. Basically my nav was graphically glitchy with the SD card inserted. I removed it a few days ago and I haven’t had the white lines of death so far. This means I don’t have nav anymore but I don’t really care since I just used google maps anyway.
hi mine has done the same as yours when removed the Sd card do I neeed to buy a new sd card I got mine from eBay
