Aw, Man :(
Surprisingly I have no discomfort this morning at all. I guess the construction of the seat and the explosively fast seat belt tensioning did its job. I have some back issues and a recent surgery so hats off to the little C.
The car has to be rebuilt on a thing called a Cellete bench that's basically a huge jig MB requires for a certified structural unibody repair. More accurate than the typical laser measured unibody rack (which itself is very accurate). The hard part on a 205 in the rear is that the skin is aluminum and the inner structure is steel. Aluminum cannot be welded to steel, so the pieces are mated at the factory using glue, and the shop now has to use glue as well. Also, while steel can be heated and reworked in large sections, aluminum has to be heated and worked in tiny little increments.
Big accident? Insurance fixes it and return it when done and lease another one.
I had plenty of "owned" cars and insurance will never pay diminished value unless you haggle hard.
Mike, with that kind of damage, you may want to make sure to check the frame out, may not be just cosmetic and may get you a new 2017. Don't know if the Xterra's front bumper actually lines up with the C.
Had this been a front end hit, with the potential for mechanical and suspension involvement I'd be much less optimistic, but knowing the shop as well as I do I'm not sweating this hit at all. Obviously the car will never be the same in my mind but since I'm just renting it...whatever.
Ever since a surgeon f'd up and destroyed the nerves to my ****** last year it takes a lot to upset me. This car thing is more an inconvenience and a minor disappointment. Shoving a tube up my shlong when I want to pee was a WAY harder thing to get past.
So I waited three months to get it built, and drove it for six months before it got hammered.
Plus he probably left his sunglasses in the bar........(j/k: a bit of humor here)
all the best, mate
ez
(ship driver, (Ret.)
The stock audio system absolutely destroys the Burmester, and honestly with a little tuning I think I could improve on the MKZ beyond my Focal/Audison set up. Ford built a better listening environment with full sets of good sounding speakers, plenty of power and CarPlay to boot.
Also, Ford's integration of LCD screens into the gauge cluster uses screen resolutions that are phenomenally high. Even small font text is brilliantly smooth and clear. Sadly, they don't make much use of it. A couple of menus and sub menus for stupid stuff you don't care about but it looks sharp as hell.
The seats are a good bit more comfortable, with more generous padding and very supple, glove soft leather.
The rest of the car is a train wreck. Somehow Ford designed a suspension that simultaneously is sloppy, floaty and loose from a handling standpoint while being stiff and uncomfortable from a ride standpoint.
Interior design is this cobbled together mess of various faux finishes, hard plastics, strange gaps, and odd proportions. Also, the row of buttons down the entire left bezel of the center console as a transmission control just looks goofy.
The front of the car has an upscale Bentleyish vibe that's handsome. Then the ***-end turns into a mullet.
