New UK C300h Hybrid Owner - no start/stop or electric even on Eco?
First Question - On the 3 hour drive home (A roads, M25 then London suburbs) from the independent dealer, even with the battery up in the 70% area and in Eco Mode the car would not start/stop or use electric. I even turned the air con off to give it a hand. Music, Sat Nav and lights were all on but even so I thought in that situation it should cut in at the traffic lights. This morning I didn't drive the car but I did get in and start it. The battery was at 75% I think and the diesel came straight on. I thought it would start in Electric mode if I was stationary? Maybe a bit too soon to worry - but should I?! I can try and get it booked in to MB this weekend if i need to.
(PS For those W205 owners without the hybrid, you can't actually turn of ECO start/stop on these, so it is not that.)
Thanks for any thoughts.
This morning I did exactly the same route as a few days ago, and it's now running in battery only mode when load conditions are reduced or when stopped.
It looks like the car senses when the low voltage battery (the regular 12 V car battery) is down, and does not allow the car to disable the engine, as there is insufficient charge to run all the auxiliary equipment, fans, steering etc. The 12V battery in a C300h will see more load than a conventional C250d, as the engine is cutting in and out while moving (not just while stationary), and also running equipment while coasting.
If you have a decent battery charger, try that. Easy to locate the positive terminal under the slider flap and the earth post is just in front for the negative; it's also detailed in the manual.
This looks like yet another aspect of the C-class, in this case hybrid specific, which has been poorly designed.
Its been a while but I found your reply which could help to resolve the issue I am experiencing with the Merc C300h (hybrid) 2016 model.
Did you connected in the front under bonet where jump start is? or did you tried connecting at the battery itself by disconnecting all cables from the battery.
Also while using CTEK battery charge did you choose AGM mode? i m planning to buy this for charging the battery.
or can i use below
https://www.amazon.co.uk/CTEK-MXS-5-...286758601&th=1
or can i use below
https://www.amazon.co.uk/BUDDYGO-Int..._t1_B07ZNL3MC4
I had the original battery replaced under warranty, I waited until it was in a fairly depleted state and not running in E mode, took it to the dealer. They said the only thing it could be is the battery so replaced it. I try to make a point of using the CTEK every couple of months to keep the 12V battery topped up to preserve the E mode. It's still going well, almost 50,000 miles on the clock now, I mostly service it myself and have had zero mechanical or electrical problems other than a blown bulb in the drivers door handle courtesy light - cheap to buy but took me over an hour to fit as you have to access from the inside removing the door card and window pane.
edit : I should have added the problem of not running in pure E mode if you dont keep the battery topped up is worse in winter time and cold conditions. Also in the summer the car should start up in E mode, in winter it will always start up in engine mode then only switch to E mode after a few miles.
my car is hybrid and it has a battery in the rear boot.
I also have a jump start option in the front bonnet where the engine is located. I believe it's safe to connect it on the jump start?
Thanks for the other note: I had a dashcam installed at the same time when the winter is starting hence. One day battery run out due to the dashcam left on and since I am having similar issue others mentioned i.e. not running on hybrid mode or stop-start feature while waiting in the traffic. I also notice about E mode and C mode as you mentioned.
I also realise my terminology was inaccurate and misleading. When I referred to E mode I meant electric only mode and not the E (economy) drive select option!
