More about wiper blades ....
I just ordered a pair of Bosch Icon winter blades. I checked several sites, and all listed the 24" size as correct for the 2015 C300. I also checked on how to replace the blades, and got two different versions. One shows merely pulling the wiper arm up, then twisting and sliding the blade off of a pin. The other shows letting the arm swipe up, then turning off the ignition. There is then a slide shown which is moved to remove the blade.
Does anyone here have any experience changing out these blades? Which procedure is correct, and is the 24" size shown correct? Supposedly, the OEM blades are made by Bosch, and they do list an OEM version, but I'm hoping the Icon blades will offer better longevity with fewer problems.
I spoke with a tech at the place I ordered from, and he said every parts book he has shows the 24" size as proper for the W205. He will check further and call me back.
The blade angle can impact the blades pass on the glass and twisting the metal arm section can yield improvement, particularly if experiencing judder.
If the appearance is streaking its worth making sure everything is clean, and that means taking more time than a little car wash.. cleaning the blades with some mild solvent like methylated spirits will ensure grease and oil from traffic film is removed.
Similarly the glass cleaning, often you'll need more than windex...
Perform a standard wash on the glass
Now while soap suds are on the screen perform a baggie test, it may feel rough if so....
Then use a fallout remover (such as iron-x)
Then clay the glass with either traditional clay or with newer synthetic clay pads / cloths..
Now perform a baggie test on the glass and it should feel slick ad smooth to the touch
You can simply clean the glass now with something like stoners invisible glass inside and out and be fine.
If however you have some light scratches in the screen you can polish it with cerriglass a rayon pad and a rotary polisher will get rid of any remaining film, remove light scratches and smooth the glass surface.
IF you still have wiper issues after this then yes its the blades..
Doing the above once a year keeps the glass pretty much as new aside form the fine chips from stones.....
DBOC, i'm on the GC and if you have issues such as this, happy to help hit the glass with the glass polish etc..
I have confirmed with MB-USA that all W205's use 22" blades, not 24". I have no idea why every online parts house specifies 24" blades for these cars. Even Amazon says 24" blades. My guess is that MB never supplied the updated information, since the W204 used 24" blades.
I have tried several different glass cleaners, and the glass does feel smooth. The blades look okay, but both sides still smear terribly. I'll try another round of cleaning both the glass and the rubber again, but I'm not overly hopeful. Considering how expensive the OEM blades are, one would expect superior performance and longevity. A six or seven month life cycle is absurd.
If all else fails, I'll have to order the OEM blades again. My local garage is trying to find an alternative, so maybe they can come up with something.
My car is a 3/2015 build, so something must have changed along the way. The Bosch 22 OE will not work. What we appear to have now is a proprietary wiper arm that conforms to no known industry standard. The fact that MB has never released the specs for these blades makes it virtually impossible to find any aftermarket solution. Every online source shows the old W204 24" size as correct for the W205, which is completely wrong.
So, guess what I had to do? I just had my garage order a set of grossly overpriced and low quality OEM blades. I am not a happy camper. This just strikes me as incredibly stupid and totally unnecessary.
You should try your dealer first. They have dealt this issue before with various Mercedes that's having this problem.
The wiper arm on W205 may have different types as they changed the design along the way.
