UK Speed Camera GPI file
Old Mar 30, 2017 | 08:10 PM
markchenguk's Avatar
C200 AMG Line (2015)
Hi,
Can someone post a copy of the GPI file for UK speed cameras?
added on 31/03/2017:
I found a free website www.POIPlaza.com which you can download by category "speedcam" and pick GB (UK). It may not be as updated as other fee-paying service but it is good enough for me and free. I found 5 types of speed camera for the UK. Download as Garmin CSV files, unzip and use Garmin POILoader to create the GPI file. Make sure you select Feet/MPH option for the UK. Copy to POI folder on the SD card. I will give it a test drive tonight.
Old Mar 31, 2017 | 02:59 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Is that legal to do so?
Old Mar 31, 2017 | 05:35 AM
guhvies's Avatar
2017 C43 AMG Saloon
For the seed cameras, I guess so. A farming solicitor might know more or you could check with DEFRA.
Old Mar 31, 2017 | 06:08 AM
ManiacGT's Avatar
I should imagine the outcome may take a while... almost an entire season.
Old Mar 31, 2017 | 07:14 PM
Originally Posted by markchenguk
Hi,
I used the Garmin POI Loader but it won't detect the SD card so I output it to "Computer". Then I copied the "UK Camera.gpi" to SD card\garmin\poi folder.
According to https://mbworld.org/forums/c-class-w...map-pilot.html, the gpi filename needs to contans "camera" or "redlight" to have alert. Don't know how true this is.
I put the SD card back into the car. I cannot find any POI category, nor I found the camera nearby my home. I can see the coordinates of the camera in the csv file.
Any idea, anyone?
Old Apr 1, 2017 | 01:43 PM
Just tried it on the road. I have the warning and the quiet bing-bing but cannot see the icon on the map. I have changed the bmp file to 24x24 pixels with 256 colours. Still it doesn't show the icon on the map.
Interesting reading how to customise your POI file: http://www8.garmin.com/products/poil..._poi_files.jsp
All seems fine but the icon still not showing on the map.
Old Apr 3, 2017 | 04:45 AM
C300H-Stu's Avatar
C300h Bluetec
My attempt is similar, no icon on the map.
I do get an alert (in what appears to be Chinese) and the bing-bong 0.2 miles away from the reported camera.
I will have another try tonight as I must have done something wrong.
Old Apr 3, 2017 | 07:06 AM
I understand a lot better in creating gpi file. Did you create the GPI file from csv? If you personal message me the csv files, I can have a look for you.
Mine is working expectedly except the 24x24 icons not shown in map. I have a red bar with the name of camera appears at top if my speed is higher than the limit. A generic icon later appears in the top left corner as I drive past the camera. I admit it will be better if it show exact location of the camera in the map. However, it does the trick and I am pleased with the result.
Old Apr 3, 2017 | 07:11 AM
C300H-Stu's Avatar
C300h Bluetec
I combined two csv files in mine, that may have been a mistake.
One for permanent and one for mobile. It reports a lot of camera's that are not there, but used to be or are temporary.
I just get the camera names in Chinese.
I can send the csv's when I get home.
Old Apr 3, 2017 | 11:43 AM
All,
I have just clarified with Brad Wiseman (Garmin) regarding the missing icon. As soon as he heard I am using Mercedes Map Pilot, he said Mercedes had requested them to disallow any customised icon in the map.
Brad's exact words (2017-04-03):
"Preventing the addition of user-supplied icons to the map display was one of the things they [Mercedes] required and Garmin was asked to remove that capability. You can still use Custom POIs but you can't add icons to the map display."
Old Apr 3, 2017 | 04:36 PM
C300H-Stu's Avatar
C300h Bluetec
Maybe if we can find non custom icons, these can be used to display something!
Retesting a new POI/gpi file tomorrow.
I had 2 custom POI's maybe this caused an issue
Old Apr 3, 2017 | 05:25 PM
You are allowed multiple GPI files so it won't be the matter. If you can send me the csv files, I can have a look.
I think I have got everything working as expected. According to Garmin, Mercedes doesn't allow their software to display icons so I have given up to display the icons.
Old Apr 24, 2018 | 09:05 AM
Wr1ghtym's Avatar
C200 Sport
alert is in chinese
Hi, did anyone get to the bottom of why the alert is in chinese?
Old Dec 1, 2018 | 01:24 PM
Dell's Avatar
2009 c class 180k blue efficiency
Comand POI
It may be a bit late but I used this (http://mb.jack-nicholson.info) to convert speed cam and put on SD card and it works great on my merc ntg 4.7
Dell
